Papago! Vietnam 8.2.0
Thảo luận trong 'Phần Mềm App Store' bắt đầu bởi akaoko, 8 Tháng chín 2011.
  1. akaoko Thành viên
    • $49.99
    • Category: Navigation
    • Updated: Sep 06, 2011
    • Current Version: 8.2.0
    • 8.2.0
    • Size: 371 MB
    • Language: English
    • Seller: Maction Technologies, Inc.
    • © 2011 Maction Technologies, Inc.
    Rated 4+
    Requirements: Compatible with iPhone, iPod touch, and iPad. Requires iOS 4.0 or later.
    Description
    PAPAGO!M8 is Now on your iPhone! The superior navigation software from Maction Technologies can now be installed onto your iPhones!
    With the PAPAGO!M8 you can transform your device into a professional navigation system.
    IMPORTANT NOTICE & SUGGESTIONS
    1.Don't operate the iPhone while driving.
    2.If you want to install Papago into iPod touch, be sure that you have the BT GPS receiver.
    3.Because of the accuracy of AGPS is not reliable enough, so Papago will not use AGPS signal.
    4.If the GPS signal is seperated by the heat reflective shield, the external antenna is needed.
    -FEATURES
    •Intelligent Search Function
    •Simple, User Friendly Interface
    •Fast Route Calculation
    •Comprehensive Map Data
    •No need to Connect to Internet (Wi-Fi/3G)
    •Free Map Update
    -POWERFUL SOFTWARE FUUNCTIONS
    •Multi Navigation Mode: 2D/3D/Split Screen
    •i-Fly Touch Screen Interface
    •Simulation Inside Tunnels
    •Portrait/Landscape Dual Mode Support
    •Auto Zooming the Map by Speed
    •Day and Night Mode for Display
    •Visual and Sound Alarm for Speed Camera
    •Built-in 3D Building
    •Built-in 3D landmarks
    •Junction Views (coming soon!)
    -DETAILED MAP DATA
    •The latest Vietmap's map (full Vietnam)
    FAQ:
    Why No GPS signal on iPhone?
    1. Please make sure Location Services is switched on. On your iPhone, go to Settings > General > Location Services.
    2. Remove the handset restricting if there's any.
    3. Some vehicles have a heat reflective shield embedded in the windscreen, which may prevent your iPhone from locating your current position.
    4. Your iPhone must be outdoors to locate your current position.
    Why the battery draining so fast?
    1. GPS navigation system need to set the backlight always on, so 100% full battery can be used for 1.5 hours.
    What's New in Version 8.2.0
    map update
    iPhone Screenshots
    PAPAGO! VIETNAM 8.2.0 đây nè
    Link:
    Nối lại bằng cái này :
    Mình mới cr đó
    Các Bro test nhé.
    TomRyan8891, thieuhc, dahgsm and 10 others like this.
  2. FeandMo
    FeandMo Staff Member
    Test lào! Mấy nước khác update lên lâu rồi giờ mới tới VN!
    TomRyan8891 thích bài này.
  3. dahgsm
    dahgsm Thành viên
    Hiển thị tiếng Việt không tốt bác ơi
    Mất hết mấy chữ có dấu rồi
    Máy em 3GS 4.1
  4. xuantrung
    xuantrung Thành viên
    Tối qua tìm al nhưng không có, bây h đã có cảnm ơn bạn. cùng test nào!
  5. duongpham
    duongpham Thành viên
    Bạn copy font "arial.ttf" từ thư mục "System/Library/Font/Cache" sang thư mục "var/mobile/applications/XXX-XXX/PPG!VNPRO.app/Navi", sau đó đổi tên file này thành "bgtr00m.ttf" là ngon ngay, bản này đã tích hợp voice tiếng việt nên các bạn vào settting của papago mà đổi nhé. thân
  6. leoaudio13
    leoaudio13 Thành viên
    Ngon lành cành đào! thêm font và đổi file trên ipad chạy ngon tuyệt! + với Retinapad thì ôi thôi rồi ! quá đã! Cám ơn bác chủ thớt!
  7. phongluu060
    phongluu060 Thành viên
    các Bác thật là tuyệt...tks các Bác nhiều nhiều nhé.
  8. MaiPhung
    MaiPhung Thành viên
    Mình là new bie nên không biết cách để vào phần system, mong bạn chỉ giáo hộ nên dùng chương trình nào để can thiệp dc ạh... Thank's
  9. akaoko
    akaoko Thành viên
    Bạn dùng IFile để làm như hướng dẫn.
    Mong bạn thành công
    MaiPhung thích bài này.
  10. MaiPhung
    MaiPhung Thành viên
    Mình dốt quá chả biết IFile là thế nào, mong Bạn chỉ giáo rõ hơn hoặc cho minh số phone để mình liên lạc, hay gửi qua mail maiphung272@gmail.com ... thank
