Pavtube HD Video Converter for Mac 1.8.1.1498
Thảo luận trong 'MAC OS: THÔNG TIN PHẦN MỀM' bắt đầu bởi pressimac, 30 Tháng tư 2010.
  1. pressimac Thành viên
    Pavtube HD Video Converter for Mac is designed for converting HD video formats from HD camcorders or DVs (like JVC, Panasonic, Sony and Cannon), non-protected HD or Blu-ray movies, DVR files (*.tivo) to other formats for playback on most popular portable devices like Apple TV, PS3, Xobx, Xobx360, WD TV HD Player, PSP, iPod, iPad, iPhone, iPhone 3G cell phones,BlackBerry, Creative Zen, iriver, Zune, etc and edited
    With Pavtube HD Video Converter for Mac you can:
    Convert, edit, or compress videos from HD DVDs or camcorders.
    Convert without any out-of-sync problem.
    Deinterlace and reduce image noise to keep better quality.
    Trim, merge video, or watermark to edit video.
    Support VFW codec encoding and 5.1 channel audio output.
    What's New:
    - Added customized output formats for iPad and TiVo Directly Copy in profile list.
    - Refined the GUI to be more user-friendly, including added scale value to Brightness, Contrast and Saturation and Volume in Edit interface.
    - Now apply Deinterlacing facility by default.
    - Date: Mar 1, 2010 (v1.8) - Added the option of automatic shutdown.
    Key Features:
    Comprehensive editing function
    You can trim the video to be a certain length and crop the video to set the size of the screen as well as set the effect by changing brightness, contrast, saturation, volume of the video. Choose the specific effect model from Simple gauss blur, Simple laplacian sharpen, Aged film, Flip color, Invert and None. In addition, you can horizontally and vertically reverse the picture.
    Manifold Mobile players
    Pavtube HD Video Converter for Mac supports almost all portable players like iPod, iPad, iPhone, iPhone 3G, Apple TV, PSP, BlackBerry, Creative Zen, iriver, Zune, etc.
    Deinterlacing to get better video quality
    This program can remove interlace on videos from Interlaced scanning cameras, Interlaced DVs, or DVDs.
    Watermark the video with company logo, text, or video
    This fantastic program provides unique watermark adding and editing function. You can add and edit not only text and image watermark, but also add video watermark to create "Picture-in-picture (PiP)" effect. VP6 alpha video watermark is also supported.
    Perfect Audio Video sync
    With the AV-sync conversion technology, you won’t get the out-of-sync problem with this program.
    Capture attractive images
    With this program, you can capture any part of the video as snapshot. The images can be found in snapshot folder.
    Merge multiple videos
    Check the option Merge into one file on the main interface to merge the several videos into one file, if you want to convert multiple videos without any interruption.
    System Requirements
    1G Hz or above PowerPC G4/G5 or Intel processor
    Mac OS X (including Mac OS X 10.4 Tiger, v10.5 Leopard and v10.6 Snow Leopard) on iMac, MacBook, Mac Pro, etc.
    512 MB physical RAM (memory) or more
    1024*768 or higher resolution display
    Download Pavtube Mac HD Video Converter:
    http://download.pavtube.com/hd-video-converter-mac/hdvideoconvertermac_setup.zip
