Pavtube iMedia Converter for Mac 1.0.*.1596 Pavtube iMedia Converter for Mac is an all-in-one Mac Blu-ray & DVD ripper and Video Converter. It helps you back up or rip blu-ray disc and DVD (ISO image file included), no matter encrypted or non-encrypted, and convert videos of all popular formats to your hard drive for playing with. iMedia Converter supports conversion for all popular mobile players and devices such as iPod, iPhone (iPhone 4 supported), iPad, Apple TV, Xbox, PS3, Zune, Archos, PSP, 3GP, Blackberry, Droid, Nexus One etc. It also converts HD video footages from Cameras and Camcorders to common video and editable HD video format for non-linear editing software like iMovie, Final Cut Express, Final Cut Pro, Final Cut Studio, Avid, Adobe Premiere etc. and extracts audios from blu-ray disc, DVD and video with high conversion speed. -Enjoy videos and movies from disc, ISO image file, cams, DVRs, web videos freely. -Easy to use but powerful editing facilities like crop, trim, watermark, flip, etc. -Outstanding audio video sync technology makes perfect matching for converted files. -Provides perfect audio solutions and up to 7.1 channels output option. Download: Mã: http://download.pavtube.com/imedia-converter-mac/imediaconvertermac_intel_setup.dmg Home: pavtube.com What's new - Reinforced the handling of TiVo files. - Added optimized output formats for iPhone 4. Key features One-step backup for blu-ray and DVD movie The Disk Copy option allows you to backup the entire Blu-ray disc and DVD to Mac, including video/ audio streams, commentary, menus, titles, ads etc. All you need is one click on 'Disk Copy' button. Special focus on High-definition videos High-definition videos can be compressed to common video or re-coded into other formats and retain HD quality. What’s more, deinterlacing facility is provided for eliminating the interlacing lines of HD footages taken with camcorders. Full support for recorded TiVo shows The app could decrypt *.tivo files, restore them to lossless *.mpg files, trim out commercials and trans-code the *.tivo files to *.vob, *.mpg, *.avi etc for burning. Convert animated images to video files at ease With iMedia Converter you will have more fun with animated pictures (GIF image) by converting them to short video files. Support universal players and devices By customizing formats and settings, the output video and audio files can be played back well on iPad, iPod, iPhone, GPhone, Blackberry, 3G phone, Nokia, Sony Erickson, Motorola cell phones, Apple TV, PS3, Xbox 360, WD TV Live, Zune, Creative Zen, Archos, PSP, Pocket PC, etc. Super high converting/ ripping speed Its advanced coding technology accelerates the conversion speed to great extent. With this iMedia Converter, you can convert videos, DVDs, Blu-Ray discs much faster than other similar tools. Multi-task operation and batch conversion The app multitask is based and supports batch conversion, this means you can load in videos, DVD and blu-ray movie and convert/ rip them at one time. Ability to merge files together and trim out unwanted clips With ‘Merge into one’ function, video clips, DVD and blu-ray movie can be merged into one file when it is necessary. With ‘Trim’ function, you can easily cut the selected file to any length and get rid of commercials, titles, header, trailer, etc. Capture still images as you wish It not only lets you preview the video, but also makes it easy enough for you to take snapshot- simply with one click. You may also change the images to favorable format at specified size. Advanced audio and video sync technology The program adopted advanced audio and video sync technology, and has improved audio video synchronization to perfect performace. Multiple aspect ratios available iMedia Converter offers more than switching between 16: 9 and 4:3 aspect ratios, it allows you to set the video to desired value to fit for the screen of your devices and meet your special demands. Various watermarks editing options The program supports different watermarks including text, image (including GIF), and video watermark. Auto-shutdown facility When working with large videos and blu-ray discs, a lot of time is consumed in producing the final video files. iMedia Converter conveniently shuts down your Mac on completion, saving valuable power and time. Required system -Operating System: Mac OS X 10.5 above (including Mac OS X 10.5 X Leopard,Mac OS X 10.6 Snow Leopard) on iMac, MacBook, Mac Pro, etc. -Memory: 512 MB physical RAM or above. -Processor: Intel processor. -Monitor: 1024*768 or higher resolution display. -Optical drive: DVD Drive, External BD drive for ripping blu-ray disc.
