Pavtube MOD Converter for Mac 1.8.1.1388 Pavtube MOD Converter for Mac is an ideal tool for JVC Camcorders (such as JVC Everio GZ-MG330) users to edit and convert MOD videos on Mac OS. Its powerful edit functionalities allows you to personalize the recording video MOD from your digital camcorder in the way you like, and then output other popular video and audio formats like MP4, 3GP, AVI, MPG, MPEG-4, FLV, MOV, 3G2, VOB, MP3, FLAC, MKA, OGG, WAV, AC3, M4A etc. With Pavtube MOD Converter for Mac you can: Fast convert MODs from JVC, Panasonic, and Sony camcorders. Compress, trim, crop, add special effects and different watermarks. Upload the recording content online with converted FLV formats. Backup the recording videos in your computer or mobile devices. Support VFW codec encoding and 5.1 channel audio output. Overview: Pavtube MOD Converter for Mac is an ideal tool for users of JVC, Panasonic, and Canon MOD Camcorders (such as JVC Everio GZ-MG330 ) to edit and convert MOD videos on Mac OS. Its powerful edit functionalities allows you to personalize the recording video MOD from your digital camcorder in the way you like, and then output other popular video and audio formats like MP4, 3GP, AVI, MPG, MPEG-4, FLV, MOV, 3G2, VOB, MP3, FLAC, MKA, OGG, WAV, AC3, M4A etc. What's New: Date: Mar 1, 2010 (v1.8) - Added the option of automatic shutdown. Date: Dec 5, 2010 (v1.8) - Fixed for crashes that occur when the software works with Intel Core i5/ i7. Reinforced the merging feature. Date: Dec 31, 2009 (v1.7) - Further optimized the performance of audio video synchronization. Added new profiles and allows the users to customize and save profile settings. Made watermark function easier to use. Date: Oct 15, 2009 - Added function of keeping original aspect video in Crop window. Added options of Auto Rename, Overwrite, Skip the file for the same existed converted file. The output profile, folder settings converted last time will be remembered by this program when start again. Added new content Zune HD as output format for Zune users. Features Highlights: Easy to use interface You will be expert when using the MOD tool since its easy-to-use intuitive interface allows you to find any options you need. Faster conversion speed This program optimized its conversion speed, so that you can convert the MOD in less time Simple gauss blur effect Simple gauss blur effect is very useful to recorded file formats, since it can eliminate the recorded videos noise. If you like, you can also add other special effects including simple laplacian sharpen, gray, flip color, invert, aged film and deinterlacing. What is worth mention is the deinterlacing, which can convert interlaced video into a non-interlaced form, so that you can enjoy a better and clearer video effect. Accurate trim the special length of MOD video The trim function allows you to get a specific length of MOD video accurately since its inner seek function can capture any key frame of the MOD. Crop MOD clips You can cut off the black edges and unwanted MOD video area easily. Merge multiple videos and replace original audio You can join multiple videos into one bigger file for conversion, as well as replace the original audio with other sounds you like. Add text, image, and video watermark This program supports to add different watermark types, including text, image (including GIF), and video watermark to the MOD. With its video watermark function, you can add a picture-in-picture effect to your video. Capture the snapshot images You can capture the snapshots images as your wallpaper or editing elements if you like. Audio and video sync technology The program adopted advanced audio and video sync technology; never let you troubled by the audio and video issues. Built-in codec Its built-in codec will not install any codec on your computer, so as to avoid the unexpected codec problem. System Requirements 1G Hz or above PowerPC G4/G5 or Intel processor Mac OS X (including Mac OS X 10.4 Tiger, v10.5 Leopard and v10.6 Snow Leopard) on iMac, MacBook, Mac Pro, etc. 512 MB physical RAM (memory) or more 1024*768 or higher resolution display Download Pavtube MOD Converter for Mac: Mã: http://download.pavtube.com/mod-converter-mac/modconvertermac_setup.zip
