Pavtube MTS/M2TS Converter for Mac 1.8.1.1498 Pavtube MTS/M2TS Converter for Mac is specially developed for AVCHD digital camcorder users. It aims to help videographers and amateurs to convert the high definition footages (*.mts, *.m2ts, *.m2t) to be editable in editing software like iMovie, Final Cut Express, Final Cut Pro etc with least quality loss. It also converts the AVCHD files to common video and audio formats, such as MP4, 3GP, 3G2 AVI, MPG. MOV, MKV, AVI, FLV, VOB, SWF, MP3, FLAC, OGG, WAV, AC3, M4A, MP3, WAV etc. With Pavtube MTS/M2TS Converter for Mac you can: Convert and compress videos from Blu-ray DVD or HD camcorders. Deinterlace, trim, watermark to edit the videos. Perfect video-audio synchronization. Multiple video picture and sound quality optimizing functions. Support VFW codec encoding and 5.1 channel audio output. What's New Date: May 5, 2010 (v1.8) - Fixed for the out of sync issue when merging multiple trimmed files together. - Improved the GUI to be more user-friendly. Date: April 16, 2010 (v1.8 ) - Added customized output formats for iPad. - Refined the GUI to be more user-friendly, added scale value to Brightness, Contrast and Saturation and Volume in Editor. - Now apply Deinterlacing facility by default. Home: pavtube.com Download Pavtube MTS/M2TS Converter for Mac: Mã: http://download.pavtube.com/mts-converter-mac/mtsconvertermac_setup.zip Key Features: Intuitive interface You are expected to enjoy the MTS video with easy steps, with the help of the intuitive streamlined UI. Multi-thread technology supports faster conversion speed This program optimized its conversion speed with multi-thread technology, so that you can convert the MTS 1.5 or 2 times faster than other similar programs. Simple gauss blur effect Simple gauss blur effect is very useful to recorded file formats, since it can eliminate the recorded videos noise. If you like, you can also add other special effects including simple laplacian sharpen, gray, flip color, invert, aged film and deinterlacing. What is worth mentioning is the deinterlacing, which can convert interlaced video into a non-interlaced form so that you can enjoy a better and clearer video effect. Accurate trim and crop your AVCHD (*.m2ts or *.mts) The accurate trim and crop function allows you to trim the proper time length for MTS/M2TS videos, as well as cut off any unwanted area. Its original video and output video preview windows will also be convenient for you to edit. Merge multiple videos You can join multiple videos into one bigger file for conversion, Replace original audio To replace the original audio is easy to be realized under the Editor sections. Add text, image, and video watermark This program supports to add different watermark types, including text, image (including GIF), and video watermark. With its video watermark function, you can add a picture-in-picture effect to your video. Catch wallpaper or editing images If you want to capture video images as your wallpaper or editing elements, just click the snapshot on the preview area. Audio and video sync technology The program adopted advanced audio and video sync technology; never let you troubled by the audio and video issues. Built-in codec Its built-in codec will not install any codec on your computer, so as to avoid the unexpected codec problem. System Requirements 1G Hz or above PowerPC G4/G5 or Intel processor Mac OS X (including Mac OS X 10.4 Tiger, v10.5 Leopard and v10.6 Snow Leopard) on iMac, MacBook, Mac Pro, etc. 512 MB physical RAM (memory) or more 1024*768 or higher resolution display
