Pen and Paper Animation lite - Phần mềm vẽ
Thảo luận trong 'ỨNG DỤNG TIỆN ÍCH' bắt đầu bởi Khỉ Con, 16 Tháng mười một 2010.
  1. Khỉ Con interista
    Pen And Paper Animation v1.1 S60v5 SymbianOS 9.x Signed(drawing & animation application)
    Pen and Paper is a very easy to use drawing and animation application. The UI has nice 3D look and it is very intuitive and natural to use. There are no texts at all, but instead you can see big friendly icons and images. Also small children can easily use the application. It is simple and fast to create "Disney-style" frame based animations
    Features:
    - 3 different pen sizes
    - 3 different brush sizes
    - Image browse screen that allows you to load an image for editing (not in "lite" version)
    - Saving an image (not in "lite" version). Saved drawings are also visible in native Photo Gallery, where they can be viewed, sent to somebody, deleted, etc.
    - Undo / redo -dialog
    - Color palette
    - Animation creator mode
    - Browse animation frames
    - Run animation
    - Insert and delete animation frames
    - Copy and paste animation frames
    - "Onion skin"-feature, i.e. show previous and next frame transparently with the current frame
    Compatible Devices-: Nokia 5228, Nokia 5230, Nokia 5233, Nokia 5235, Nokia 5250, Nokia 5800, Nokia C5-03, Nokia C6-00, Nokia N97, Nokia N97 mini, Nokia X6
    [URL="http://adf.ly/BDxy"]Click here[/URL]
    sitrum thích bài này.
