Phân biệt iPhone 3G bản quốc tế và bản AT&T(lock)
Thảo luận trong 'Hỏi Đáp & Chia Sẻ Kinh Nghiệm' bắt đầu bởi Macbook_Pro, 27 Tháng ba 2009.
  1. Macbook_Pro Thành viên
    Nguồn Nhật Cường.
    <!--[if !mso]> <style> v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} </style> <![endif]--> <o:smarttagtype namespaceuri="urn:schemas-microsoft-com:office:smarttags" name="country-region"></o:smarttagtype><o:smarttagtype namespaceuri="urn:schemas-microsoft-com:office:smarttags" name="place"></o:smarttagtype>
    <!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:punctuationKerning /> <w:ValidateAgainstSchemas /> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables /> <w:SnapToGridInCell /> <w:WrapTextWithPunct /> <w:UseAsianBreakRules /> <w:DontGrowAutofit /> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if !mso]><object classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui></object> <style> st1\:*{behavior:url(#ieooui) } </style> <![endif]--> <style type="text/css"> <!-- /* Font Definitions */ @font-face {font-family:Verdana; panose-1:2 11 6 4 3 5 4 4 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1593833729 1073750107 16 0 415 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --></style>
    <!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Kể từ khi Apple ra mắt iPhone 3G thì trên thị trường song hành 2 phiên bản iPhone 3G là: iPhone 3G phiên bản quốc tế(QT) và phiên bản bị khóa mạng(Lock) được phân phối qua các Hãng Dịch vụ viễn thông như AT&T, Optus, Orange, Vodafon...(ở VN chủ yếu là của AT&T - Mỹ). Điểm khác biệt của 2 phiên bản này ngoài giá thành (phiên bản QT giá thường đắt hơn bản lock khoảng 100$ - thời điểm tháng 02 - 2009) còn ở tính ổn định của sản phẩm. iPhone 3G - bản quốc tế không bị khóa mạng nên có thể dùng bất cứ SIM nào có thể nghe/gọi được ngay, ngoài ra khi update phần mềm, cài ứng dụng vv người dùng hoàn toàn yên tâm. iPhone bản QT thường được phân phối qua hãng TIM, Vodafone tại Ý, Tree(3) tại Hồng Kông, Macao; hay tại một số nước như Nga , Séc, New Zealand, Singapore, Đài Loan, Thái Lan
    Với phiên bản bị locked muốn dùng phải ghép với một thiết bị gọi là X-Sim(hay còn gọi là Fake-Sim) hoặc giải mã (từ ngày 1 tháng 01 năm 2009 đã có phần mềm giải mã cho iphone 3G, không phải dùng biện pháp phần cứng nữa) cho nên tính ổn định trong vận hành không bằng, ngoài ra khi hãng Apple tung ra firmware mới để nâng cấp phần mềm cho máy người dùng bản lock không chắc upgrade được do e ngại máy sẽ bị khóa mạng trở lại không nghe gọi được nữa.
    Gần đây có thông tin là một số người bán hàng iPhone3G bản lock dùng x-Sim(ghép trong máy), hoặc unlock bằng phần mềm nhưng lại nói với khách hàng là bản Quốc tế gây thiệt hại cho người tiêu dùng. Để cung cấp thông tin khách quan giúp khách hàng tránh nhầm lẫn chúng tôi đưa ra một vài điểm để phân biệt giữa 2 phiên bản này:
    <o:p></o:p>
    1. Phân biệt iphone 3G AT&T (Lock) và iphone 3G phiên bản Quốc Tế thông qua vỏ hộp: <o:p></o:p>
    Ngay từ vỏ hộp của 2 phiên bản cũng có thể phân biệt, thường thì bản AT&T locked bán tại Mỹ có hình dáng hộp thấp, trên vỏ hộp đề rõ logo hãng AT&T. Còn phiên bản quốc tế(global) không bị khóa máy có hộp cao hơn gần 2cm, tuy nhiên đặc điểm hộp cao không phải 100% là bản quốc tế vì iPhone bản lock bán ở nhiều nước bên ngoài Mỹ cũng có hộp cao.
    <o:p></o:p>
    <o:p></o:p>
    2. Kiểm tra máy:
    Phiên bản QT thì bạn có thể cho bất kỳ Sim GSM nào là dùng được ngay. còn bản lock thì phải dùng một số công cụ phần mềm giải mã xong mới dùng được, để biết chắc chắn có phải bản lock hay không thì chỉ có cách là restore máy về trạng thái xuất xưởng, khi đó bộ nhớ máy sẽ bị xóa hoàn toàn, máy yêu cầu người sử dụng phải cắm vào máy tính kết nối với ituns để active, sau khi active xong lắp SIM vào nhận sóng ngay thì đó là bản quốc tế.
    <o:p>- Cũng có thể xem model máy: Setting> General> About nếu cột thứ nhất không bị tick(dòng Model có ký hiệu nằm trong ô đánh dấu màu đỏ) thì 100% xuất xứ máy là bản Quốc tế. Còn nếu cột thứ nhất bị tick vào thì chắc chắn là bản lock, tuy nhiên nếu cột thứ 2 cũng bị tick(</o:p>Carrier offers
    authorized unlocking<o:p>) thì có nghĩa là người mua có thể đóng một khoản phí để yêu cầu nhà cung cấp unlock. </o:p>
    <o:p></o:p>
    Come on baby, dangem, newbie and 2 others like this.
  2. xitrumhamvui
    xitrumhamvui Thành viên
    --> Bạn nói dòng đỏ nào trong About mình có thấy đâu, mong chỉ giáo rõ chút, thanks.
