Phần mềm cho Symbian 60 (N6600, SX1, N-Gage, 7610..) cập nhật liên tục P.2
Thảo luận trong 'ỨNG DỤNG TỔNG HỢP, ỨNG DỤNG KHÁC' bắt đầu bởi Volcano, 23 Tháng tư 2005.
  1. pntruongan
    pntruongan Thành viên
    Phần mềm dùng mobile làm webcam via bluetooth !!
    To minhque :
    Mình đang dùng mobiola, nhưng chỉ dùng được bản qua cáp úb, bluetooth thì chưa !! Để thử cái này xem sao vậy ????
  2. minhque
    Omaitek.OmaiProtect.v1.00.S60.SymbianOS7
    A "MUST HAVE", If you lost your phone,OmaiProtect not only keeps it inviolated,moreover it helps you to get it back efficiently by sending you the phone# of 'who is using it’ !!!
    OmaiProtect :
    OmaiProtect is an application used for mobile phone to keep your personal confidential information and out of being stolen. Moreover, OmaiProtect has special feature that is connected world wide database association to track status of any phone by reference to the phones unique identifying code ( IMEI number). Through this feature users can have more chance to get the phone back if its lost or stolen.
    User information:
    Enter your personal information: your name, password, the primary phone number and the secondary phone number. Username and password are letters or numbers that you create your own but not more than 8 characters/digits. After you have created your password, you may need to memorize them to log on the program or exit the locking screen. The primary and secondary phone number could be your close friends or family members. So when somebody else use your phone and enter wrong password three times or your SIM being replaced, the program will send SMS messages automatically to these phone numbers let them know that your phone being used by someone else. You have to enter your name, password, the primary phone number fully. The secondary phone number is your option, you may chose to have it or not.
    Set-up :
    - Immediate-lock: once you want to lock your phone immediately,simple press and hold the * key (key star) in a few seconds.So keep your phone now in safe status.
    - Auto-lock: This option will alow you to set the lock-time when it’s idle. The phone will be automatically locked up, and the lock screen will show up to protect your phone after the selected time ended.
    - SMS syntax: is via remotely locking your phone by using SMS messages from any other mobile phone. When you want to lock your phone from other cell-phone, you need to set up with following message: SMS syntax_password then send it to your phone. With SMS syntax those are letters or numbers that you create by your own or you can use ours as OmaiProtect, is the blank space on your mobile phone, password you can create your own. When your mobile phone receives above message, OmaiProtect will lock up your screen to secure and protect your mobile phone.
    Use
    to display menu features, use "FIRE" button to select the feature you want. Go to "Option" and select "Information change" to amend your personal information, or select "Save and back" to return to main menu.
    Omaitek
    Omaitek is the Global Software Company that is aiming to entertain mobile phone’s consumers by offering handy and funny softwares and contents for the mobile phone world.
    Compatible Devices
    Nokia 3230
    Nokia 6260
    Nokia 6600
    Nokia 6620
    Nokia 6630
    Nokia 6670
    Nokia 7610
    Nokia 9210 Communicator
    Psion Siena
    [FONT=&quot] Tải về [/FONT]
  3. minhque
    Lonely.Cat.Games.SmartMovie.v3.12.S60.SymbianOS (của BiNPDA)
    Bản này cài luôn chứ không cần phài cài đè các phiên bản cũ nữa
    [FONT=&quot] [​IMG]
    [/FONT][FONT=&quot]
    [/FONT]SmartMovie is a video player for your mobile device, with counterpart PC converter utility. With the converter, you may prepare any video clip for playback on your mobile device.
    Play your videos on your mobile device, anywhere, anytime, you need just a few steps:
    * Convert any video file on your PC into a phone-friendly video file.
    * Upload video into device/memory card.
    * Play the video in SmartMovie Player installed on your mobile device.
    [FONT=&quot][​IMG] [/FONT]
    Features:
    * Standard AVI format, allowing you to preview converted files on your PC.
    * Player uses the phone screen in portrait or landscape mode, utilizing full screen size of the device.
    * Rescaling of video to utilize full-screen area.
    * PC converter allows you to split video file into multiple segments, so that it fits onto your memory card, if not entire, then cut to more parts - you may watch your favorite video in parts, e.g. while traveling to work/school.
    * Support for subtitles - allowing you to watch movies in different languages.
    * Friendly PC converter - preview videos on PC, select parts you want to convert, alter quality.
    * Supports DirectShow codecs, so you may use video codecs downloadable from the internet.
    * Very fast conversion; on standard PC conversion is 5x faster than video clip playback time. You'll convert entire movie in just a few minutes
    * Bicubic rescale algorithm shrinks video to small screen size in best possible quality.
    * Adjustable quality parameters for video and audio streams, allowing tuning target video to your needs.
    * Customizable video Player (brightness, language, volume, and more).
    Play movies in portrait or landscape mode - whichever way you like.
    Requirements:
    * Mobile device with one of supported operating systems (Symbian, Windows Mobile, Palm, Linux)
    * PC with Windows 98/ME/2000/XP
    Compatible Devices
    Nokia 3230
    Nokia 3600
    Nokia 3620
    Nokia 3650
    Nokia 3660
    Nokia 6260
    Nokia 6600
    Nokia 6620
    Nokia 6630
    Nokia 6670
    Nokia 6680
    Nokia 6681
    Nokia 6682
    Nokia 7610
    Nokia 7650
    Nokia N-Gage
    Nokia N-Gage QD
    Nokia N70
    Nokia N90
    Nokia Series 60
    [FONT=&quot]
    Tải về [/FONT]
    snake688, nolf, vilube and 2 others like this.
  4. verylove
    verylove Staff Member
    cái này chĩ dùng BT được thôi hã bạn ? Còn bạn dùng cái mobiola thì dùng dtdd làm WC qua cáp USB hã , bạn có hok cho mình đi chứ mình hok có bT
  5. nhikhan
    nhikhan Ex-Mod
    Warelex Mobiola WebCam v1.04 S60 SymbianOS Cr@cked - BiNPDA
    ---Dùng cổng USB---
    ---Chọn Disable soft anti-virus trước khi extract file nén nhé, vì file loader.exe chương trình sẽ thông báo !!! ---
    The first application that realistically turns your Symbian phone into a webcam and truly replaces your USB camera. Works over Bluetooth!
    Turn your Symbian phone into a high-quality wireless Bluetooth-based web camera and throw out your bulky USB webcam. Very simple to install and configure, Mobiola Web Camera 1.0 consists of two software components: (1) a client application that resides on the phone, and (2) a webcam PC driver compatible with any Windows application that can receive video feeds from a web camera including Skype 2.0, MSN and IM. Carry your webcam with you wherever you go and connect it to your laptop at anytime, no wires necessary. Try it now and experience resolution and frame rates comparable to some of the top-performing USB webcams on the market!
    Requirements
    8 MB of free disk space on PC, 68kb of free phone memory, 720kb run time memory
    Compatible Devices
    Nokia 3230
    Nokia 6260
    Nokia 6600
    Nokia 6620
    Nokia 6630
    Nokia 6670
    Nokia 6680
    Nokia 6681
    Nokia 6682
    Nokia 7610
    maidinhtai thích bài này.
  6. nhikhan
    nhikhan Ex-Mod
    ---Dùng cổng BT---
    Requirements
    Compatible Devices
    Nokia 3230
    Nokia 6260
    Nokia 6600
    Nokia 6620
    Nokia 6630
    Nokia 6670
    Nokia 6680
    Nokia 6681
    Nokia 6682
    Nokia 7610
  7. maidinhtai
    maidinhtai Thành viên
    Bản này là 1.00 mà. Bản này không khác gì bản 1.00 crack ngày 4/2/2006
  8. verylove
    mafem nghe nói Mobiola 1.00 là dùng BT còn 1.4 là dùng cáp đúng hok vậy ?
  9. pntruongan
    UH ! Bản USB chạy tốt, còn bản BT không work !!
  10. pntruongan
    minhque ơi, cái này nó work như thế nào vậy ?
    connect BT giữa mobile va pc được, Yahoo hay skype nhận được driver của flycam, nhưng flycam trên PC nó không có chạy thường trú như mobiola thì làm sao mà kết nối ???
