Phần mềm chụp ảnh màn hình điện thoại Gif Tailor
Thảo luận trong 'ỨNG DỤNG TIỆN ÍCH' bắt đầu bởi Khỉ Con, 28 Tháng ba 2011.
  1. Khỉ Con interista
    Luomc GifTailor v2.12 S60v5 SymbianOS9.4 Unsigned Ad-Free - cGiPDA
    Gif Tailor allows you create cool glitter frame gif images with your own photos or screenshots on your handsets. Tailor the use of GIF can easily create animated GIF files, with the following
    Features:
    - Support for screen shot
    - To import jpg / gif / png / bmp / mbm picture
    - To save a single picture to a jpg / gif / png / bmp / mbm files (you can achieve the image format conversion)
    - Adjust animation speed can be a unified, single frame can be adjusted
    can be very convenient to adjust the location of the frame all gif
    - Support watermark, transparent color to pure white (255, 255, 255), can be used to support the picture as a watermark
    - Support for touch screen, you can drag images to the designated location
    adjustable output image quality
    - GIF picture can be split
    Changelog:
    - Fixed part of the phone can not use the volume keys to capture the bug
    revised some of the phone can not properly use the file dialog bug (mainly Symbian 3 handsets)
    - To increase support for symbian ^ 3 models​
