pipLightControl 1.0.1 S60v3/5^3 SymbianOS9.x Unsigned pipLightControl is a light control system for Symbian devices. Basically pipLightControl runs in the background and keeps the display light turned on as long as an application is in foreground (eg. you text someone, ...), as soon as the homescreen gains focus the light system deactivates itself again. pipLightControl main components are: LightEngine: enables the display-light if any application is in foreground Config file: contains applications without permanent display-light (eg. homescreen) Very low memory consumption: 19.2k Basic main view (see screenshot) Available languages Change-log New Feature: Uid-Detector Mã: [URL="http://files.myopera.com/hth2813/mobile/s60v3/multimedia/pipLightControl%201.0.1%20S60v35S%5E3%20SymbianOS9.x%20Unsigned.sis"]http://files.myopera.com/hth2813/mobile/s60v3/multimedia/pipLightControl%201.0.1%20S60v35S%5E3%20SymbianOS9.x%20Unsigned.sis[/URL] Nguồn: symbiantalk.net
cái này là để quản lý độ sáng màn hình tức thời hay ... độ sáng màn hình khi sử dụng máy vậy bác? trong setting cũng có chỉnh display r mà
