PolarBearFarm ShowTime v1.01b iPhone OSX (Cr++ked-HSpda) Current Features: • 320 x 427 resolution • 6 frames per second capture rate • 5 second record limit on unlicensed version, unlimited for licensed users. •Raw uncompressed file format Please be aware that video is not captured in any standard compressed video format at this stage. We are currently working to add a post-process option, to convert the uncompressed captured video into a form playable by most media players. Contact us if you’d like information on the uncompressed file format captured by ShowTime. Planned Features: • Higher capture frame rate. •Post process option to transcode to a standard video format. FAQ: How do I install ShowTime? Firstly at the moment you must have a jailbroken iPhone (just until Apple get that SDK out). There are plenty of tutorials around on how to jailbreak. Then simply add our repository to Installer.app: • Open Installer, tap “Sources” at the bottom right corner • Tap “Edit” at the top right corner • Tap “Add” at the top left corner • Enter “ Code: http://www.polarbearfarm.com/repo/ ” into the popup, and tap “OK” • Tap “Done” at the top right corner • Tap “Refresh” at the top left corner. Then ShowTime will appear in the “Multimedia” category. Where are the recorded videos stored? Videos are recorded to /var/root/Media/PBFVideo/ you can use SSH/SFTP to transfer videos on and off the iPhone. PBF ShowTime is a native iPhone app that records video, which is strangely enough not available on the iPhone by default. The video recorded by ShowTime is recorded in a raw format. This means it can’t be played on your Mac or PC, plus it fills your iPhone’s memory very quickly. Polar Bear Farm, the creators of ShowTime are working on faster capture with 15 frames per second and encoding the video file a standard format, most likely MPEG. The app is for sale at the price of $10, but there is a trial version which can save up to five seconds’ worth of footage without audio. PBF will be at MacWorld 08, so if you plan on attending you can get more information there. Here is a video demo of what ShowTime can do: The other video recording app being developed currently is by Drunknbass, but that one has not yet been released to the public yet. To Install ShowTime: Assuming you have already jailbroken your iPhone, just add a new repository source to Installer.app with the URL: Code: http://www.polarbearfarm.com/repo/ . You will then find ShowTime in the “Multimedia” category. Use iPhone mods and hacks at your own risk! Installing 3rd Party iPhone apps requires you to jailbreak the iPhone before installing the native software and apps. You can use Installer.app for Mac OSX and iBrickr for Windows PC to do this. Browse the full list of all iPhone and iPod touch native 3rd party apps filed under the software category.
Có Showtime bản cr++ked khi quay xong ra định dạng*.mov không minhque. Cái này ra file *.vid khó tìm app để xem và convert trên PC
