Poweramp Music Player v2.0.6-build-508
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi BinhDa, 20 Tháng tám 2012.
  1. BinhDa Super Moderator
    Poweramp Music Player v2.0.6-build-508 play.google.com.audioplayer
    2.0is the next major release and a free update for everyone, who purchased PowerAMP Full Version Unlocker.
    IMPORTANT: PowerAMP v2.0 has completely independent Library implementation. Please ensure you have all [FONT=inherit ! important][COLOR=blue !important][FONT=inherit !important][FONT=inherit ! important]your [/FONT][FONT=inherit ! important]Music[/FONT][/FONT][/FONT]
    Folders checked in PowerAMP Settings => Music Folders to have all [FONT=inherit ! important][COLOR=blue !important][FONT=inherit !important][FONT=inherit ! important]your [/FONT][FONT=inherit ! important]songs[/FONT][/FONT][/COLOR][/FONT] in the Library.
    Features:
    [/COLOR]
    • plays mp3, mp4/m4a (including alac), ogg, wma*, flac, wav, ape, wv, tta, mpc, aiff (* some wma pro files may require NEON support)
    • 10 band optimized graphical equalizer for all supported formats, presets, custom presets
    • separate Bass and Treble adjustment
    • stereo eXpansion, mono mixing, balance
    • crossfade
    • gapless
    • replay gain
    • [FONT=inherit ! important][COLOR=blue !important][FONT=inherit !important][FONT=inherit ! important]plays [/FONT][FONT=inherit ! important]songs[/FONT][/FONT][/FONT] from folders and from own library [/COLOR]
    • dynamic queue
    • lyrics support, including lyrics search via musiXmatch plugin
    • embed and standalone .[FONT=inherit ! important][COLOR=blue !important][FONT=inherit !important][FONT=inherit ! important]cue [/FONT][FONT=inherit ! important]files[/FONT][/FONT][/FONT] support [/COLOR]
    • support for m3u, m3u8, pls, wpl playlists
    • OpenGL based [FONT=inherit ! important][COLOR=blue !important][FONT=inherit !important][FONT=inherit ! important]cover [/FONT][FONT=inherit ! important]art[/FONT][/FONT][/FONT] animation [/COLOR]
    • downloads missing [FONT=inherit ! important][COLOR=blue !important][FONT=inherit !important][FONT=inherit ! important]album [/FONT][FONT=inherit ! important]art[/FONT][/FONT][/FONT] [/COLOR]
    • 4 configurable widget types
    • configurable lock screen with optional Direct Unlock
    • headset support, automatic Resume on headset and/or BT connection (can be disabled in settings)
    • scrobbling
    • tag editor
    • visual themes, including support for external/3rd party skins
    • fast library scan
    • high level of customization via settings
    Changelog (v1.4 => v2.0) :
    Audio Engine:
    Direct Volume Control for new Android 2.3+ sound system where available. Direct Volume Control results in volume level equal (or higher with positive preamp) to stock player, but with the Equalizer/Tone enabled
    re-tuned equalizer/tone controls for Direct Volume Control (gives a larger range of distortion-free sound, deeper basses)
    output limiter. Ensures distortion-free sound even on extreme equalizer/tone amplification levels
    .mpc, .aiff
    replay gain support for all supported formats which support Replay Gain (mp3, mp4/m4a, flac, ape, wv, tta, ogg, mpc)
    Stereo X expansion effect
    mix-to-mono, balance
    Library/Folders:
    • custom complete Library/Media Scanner implementation, 10x-100x scan speed comparing to system library tag scanner
    • [FONT=inherit ! important][COLOR=blue !important][FONT=inherit !important][FONT=inherit ! important]Music [/FONT][FONT=inherit ! important]Folder[/FONT][/FONT][/FONT] hierarchical selection [/COLOR]
    • permanent shuffle. Shuffle session is stored in database and survives PowerAMP restart, phone reboots etc.
    • Menu => List Opts for almost each Folder/Library list with the sorting, view mode, and other per-list options
    • playlist unification, no more Folders vs Library playlists
    • m3u/m3u8, pls, wpl playlist file formats support
    • playlist export from system Library
    • embed cue support (flac, wv, ape)
    • full-library and folders search
    • history of songs played and other smart playlists (Most Played, Top Rated, Recently Played, Recently Added. Each list can be set to be sorted in Reverse. Enable these lists via Menu => Lists Opts in Library)
    • rating system. PowerAMP 2.0 stores ratings in own database only
    • auto-advance options moved from Settings to Advance List repeat mode
    • new Shuffle modes: shuffle songs then lists; shuffle lists, songs in order
    • home screen playlist shortcut support
    • voice [FONT=inherit ! important][COLOR=blue !important][FONT=inherit !important][FONT=inherit ! important]search [/FONT][FONT=inherit ! important]support[/FONT][/FONT][/FONT] ("Listen to") [/COLOR]
    UI:
    • restyled skins (larger controls, less controls initially visible, expandable menus, bigger album art, etc.)
    • ability to load skins from Market/apk/jar files
    • OpenGL cover animation
    • grid view for folders/[FONT=inherit ! important][COLOR=blue !important][FONT=inherit !important][FONT=inherit ! important]albums [/FONT][FONT=inherit ! important]lists[/FONT][/FONT][/FONT] [/COLOR]
    • new Equalizer/Tone and Library layouts
    • new configurable Lock Screen
    • new configurable 4x4, 4x2, 4x1, and 2x2 widgets
    • improved Settings layout and reorganized options
    Other:
    • lyrics download (via separate musiXmatch plugin)
    • more than 100 changes in total and more are coming in the next PowerAMP 2.x releases!
    What's in this version: (Updated : Jul 9, 2012)
    • Please check in-app changelog or app description for the full log.
    • fixed issue with some HTC phones @ ICS (e.g. Sensation XE)
    • smoother post-notification resume
    • some bluetooth [FONT=inherit ! important][COLOR=blue !important][FONT=inherit !important][FONT=inherit ! important]track [/FONT][FONT=inherit ! important]info[/FONT][/FONT][/FONT] support (where supported by device/stock player – Motorolas and Samsungs). Optional album/artist can be included into title for title-displaying-only BT devices (Settings/Misc/Tweaks)[/COLOR]
    • Direct Volume Control is disabled by default for LG 2X (P990)
    Required Android O/S : 2.1+
    Screenshots :
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    DOWNLOAD
    [/COLOR]https://dl.dropbox.com/u/59449626/APK/PAF%20v2.0.6-build-508.rar
