ProPaint Mobile - Công cụ vẽ và chỉnh sửa hình ảnh
Thảo luận trong 'ỨNG DỤNG TIỆN ÍCH' bắt đầu bởi verylove, 17 Tháng mười hai 2009.
  1. [​IMG]
    The graphic editor with the beautiful interface and the big possibilities. Allows both create the drawings, and to edit the existing. Also there is a possibility without leaving the appendix to receive photos from the chamber, to grasp shots from video, to collect animation from pictures of any format etc. The set of effects, tools is accessible, also there is a support of graphic fonts and a brush.
    Change Log :
    - Fixed a bug with a vertical stripe of paint brushes and a point.
    - Added function Text2Image. Open absolutely any non-graphical file (text), its contents displayed in the viewer of the text. Clicking kn.5 can transmit the contents of windows in the image editor.
    - In the editing mode when you open the camera shutter is automatically called mode photography. Button Focus - go to the screen save. Now it can set different effects.
    - Contribute to the Edit menu, click Select All.
    - Separately, made the effect of "Reflection".
    - Added the possibility of replacing the existing file when saving.
    - Added opening files from the File Manager. Malcolm'u Thank you for your help.
    - Again, added work on the phones of Siemens.
    tdnhi2002 and club7 like this.
  2. bookworm
    bookworm Thành viên
    mình đang rất cần pm này nhưng khi cài vào rồi thì k thể chọn mục open trong pm đc. chỉ mở đc mục create thôi. trước đây mình dùng phiên bản cũ thì được (k nhớ là đã tìm ở đâu, giờ format mất luôn rồi).
    mong bạn sớm fix dùm mình lỗi đó hay cho mình pm này phiên bản cũ cũng đc. mình chỉ cần pm này thôi. Thanks bạn trước!
  3. minhtue
    ProPaint Mobile v2.0 J2ME
    Change Log :
    *New hot keys (# + Joy - for quick navigation around the image).
    *Updated function for engine Text2Image aNMPWR2.0.
    *An overview of the whole picture when you view by clicking the book. *.
    *Removed support JSR-75Sie, but there are more opportunities to work on other brands of phones.
    *Optimization.
    *Changed the effect of "8. Black & White" and "9. Pasteurization", now you can adjust the degree of the border.
    *Changed effect "17. Turn", shotguns now will not.
    *Posted effects BoxBlur, Mosaic, Pencil, Twist, Glass Tiles.
    *"Serious" effects are now applied not at once, ie have the opportunity to look through them.
    *In the effects by pressing the button * you can now adjust the position of the picture.
    *Selecting fonts.
    *When you open a GIF and SWF (JP-8) can choose the frame, and in the SWF its size depends on the size of currently editing an image.
    *Posted a new encoder in PNG, must require less memory to save.
    *Added a new tool Distortion, with which you can stretch the image or its part.
    *Posted by drawing from the center. Included in the settings. For the brush, this mode is very interesting to read - what is drawn in one half of the screen is duplicated in another.
    *When the mode of drawing from the spray works like a brush.
    *If you book. # In effect if the clipboard has the image, then it will be available to apply effects. Just do not forget to deselect.
    *Minor additions and corrections​
    quangmax thích bài này.
