upgrade from Python v1.9.x to v2.0.0 Runtime with scriptshell by *nokstern* S60v3_v5 How To upgrade from Python v1.9.x to v2.0.0' (if you'd like to): 1.) Delete PythonRuntime v1.9.x via default App.manager (LEAVE ScriptShell undeleted.delete only Python Interpreter,dont worry about the warnings),restart the phone. 2.) Install Python v2.0.0 then install PythonScriptShell v2.0.0 (sign,if needed and agree to overwrite existing).click icon to launch Python v2.0.0. 3.) If asks for pips and libs install 6 files from the OS9_Pips installer.v1.60.zip (included in the .zip some of you will get a update error, meaning you dont need that file) (sign SDL_Library.v2.31 if youre phone is not hacked). restart youre phone (didnt do that in my n95) and Python v2.0.0 should run fine. maybe some apps that works with v1.9x wont work. all my apps working fine. thanks ***nokstern*** for youre time for us. confirmed working on my n95 and n97(Python v1.97), datutm his E71(Python v1.97) and nokstern his n82(Python v1.94).
Hôm trước mình sử dụng App. Update cập nhật python 2.0 này. Nhưng sau đó các ứng dụng trước đây chạy trên Python 1.9 không còn chạy được với Python 2.0 nữa.
Python v2.0.0 S60v3/S60v5 SymbianOS9.x Signed {Update:12.02.2010} This is the new 2.0.0 final release of PyS60. This release is intended only for S60 3rd edition, S60 3rd edition FP1, S60 3rd edition FP2 and S60 5th edition devices. Note on versioning: The versioning scheme in PyS60 releases is such that the releases with an even minor version (1.0.x, 1.2.x ...) are "stable" and releases with an odd minor version (1.1.x, 1.3.x ...) are "development" releases. What is new when compared with PyS60 1.9.7? --------------------------------------------------- - Repeat support in 4-way directional pad - Lot of memory leaks in the interpreter code is fixed. - appuifw.app.track_allocations can be set if the interpreter should track all memory allocations and then free the memory which was not explicitly released before application exit. To debug memory leaks in 3rd party extension modules set the value to false. - All the Pyds that have zero UID will be assigned with the applications UID at the time of packaging. As a result, Python applications can now be symbian signed. This opens the door for submitting Python applications to OVI Store. - Pdf documentation is available in the installer/archive. - API cleanup in the SensorFW module. - On the below mentioned devices Python runtime and its dependencies will be installed automatically when the Python applications is started. 6220 classic, N86 8 MP, N85, 6720 classic, 6730 classic, N96, 5730 XpressMusic, N78, 5630 XpressMusic, E52, E55, 6710 Navigator, E75, N79, 5800 XpressMusic, 5530 XpressMusic, 5230, X6 and N97 mini
bác tí ơi bộ python này cài trên thẻ nhớ được k vậy,hic n86 bộ nhớ ít quá,nếu k cài được vào thẻ thì..hic hic
Nếu muốn cài vô thẻ nhớ sao bạn không tìm bộ v1.45 cài trên thẻ đó, xài ổn lắm ( thử trên con N85, sử dụng bình thường ). Còn muốn xài thử cái mới thì bạn có thể tự thử nghiệm ( cài thử xem sao ) rùi báo lại cho các bạn khác cùng biết
hic,em cũng có bộ python đó,k hiểu sao dùng trên n82 thì ok lắm,nhưng cài vào n86 thì chỉ chạy được cái python mặc định khi mình cài vào ấy,conf những pm khác chạy trên nền python như khởi động lại máy hay hỗ trợ gỡ bỏ pm trên đt lại k sử dụng đươc.N86 khác với n82 là có cả bộ nhớ máy E,thẻ nhớ là F vậy nên rắc rối quá.Mong các pro có kinh nghiệm chỉ giáo cho em
e cài cái của bác trên con N73 đã hack khi mở lên nó báo: check if the following components are installed -> Python Runtime, -> PIPS Library máy từ trước tới jo chưa sài python lần nào và e cài lên bộ nhớ máy mong các bác chỉ giáo sớm
