QQLauncher Pro v1.4.3 - đẹp không kém Go Launcher EX
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 6 Tháng chín 2011.
  1. Khỉ Con interista
    Yêu cầu: 2.0+
    [​IMG][​IMG][​IMG][​IMG]
    [​IMG][​IMG]
    Description
    The solution couples richer functionality with superior performance.
    A superior Android-based desktop application, QQ Launcher Pro replaces conventional desktops with an enhanced range of frequently used desktop features such as screen and program management. Flashier in the looks department, the solution couples richer functionality with superior performance.
    The launcher supports the following cool features:
    1. Built-in widgets such as shortcut switches and task manager;
    2. Impressive screen-switching effects (menu > settings > screen);
    3. A complete set of program management functions, free sequencing, multidimensional arrangements, and smart searches;
    4. Quick access to the Store for users to download applications anytime;
    5. Custom folders that classify applications;
    6. One-key desktop relocation without losing anything. (Tapping OK after the first installation will guide you through importing default desktop icons.)
    7. Provide several sets of personalized skin.
    Xem thêm:
    https://market.android.com/details?id=com.tencent.qqlauncher&feature=more_from_developer
    Tải về:
    http://appstore.vn/a/index.php/home/app/1610
    nhv12, slxxtc, salemnb1 người khác thích bài này.
  2. Khỉ Con
    Cập nhật 1.3
    What's in this version:
    1.Fixed some crash bugs;
    2.Fixed color problem in some small screen.
    nhv12 thích bài này.
  3. Khỉ Con
    Cập nhật 1.3.1
    1. Add LockScreen feature
    2. Customize Market application
    3. Customize Screen and Drawer settings: hide label
    4. Customize Screen and Drawer settings: grid row size
    5. Help guide on the first use
    6. Fixed some widgets can't be added
    7. Fixed some crash bugs, optimized application speed & more stable.
  4. Khỉ Con
    Cập nhật 1.32
  5. Khỉ Con
    1.3.4
  6. Khỉ Con
    1.4
    1. Updated:
    2. Folder name classification
    3. New feature introduction
    4. Change lockscreen background option
    5. Optimized loading speed
    6. Fixed:
    7. Lockscreen bug
    8. Icons may overlap or lose in app drawer
    9. Some widgets may not work properly
  7. Khỉ Con
    1. Version: 1.43
    2. Features:
    3. Folder name classification
    4. New feature introduction
    5. Change lockscreen background option
    6. Fixed:
    7. Some Lockscreen bugs
    8. Crash while adding application in folder
    9. lag problem when flipping
  8. Khỉ Con
    Có thể nói, vị trí miến phí số 1 cho Android của Go Launcher đã bị lung lay dữ dội từ sau khi QQLauncher Pro xuất hiện. Dựa trên Launcher của Rom MIUI, so với Go Launcher, QQLauncher Pro tạo cho người dùng cảm giác mượt mà hơn và bắt mắt hơn. Ứng dụng vẫn đang được phát triển hàng ngày bởi nhóm Tencent và ở bản cập nhật mới nhất, người dùng đã có thêm tùy chọn ở màn hình khóa máy theo phong cách hoàn toàn mới. Màn hình này được bố trí cho phép bạn truy cập nhanh vào các ứng dụng gọi điện, nhắn tin hay camera.
    Chuyển đổi qua lại giữa các màn hình với hiệu ứng "khối lập phương"
    Màn hình ứng dụng được sắp xếp theo chữ cái rất bắt mắt
    Bộ công cụ giúp bạn bật tắt các chức năng của máy chỉ bằng 1 lần chạm
    Sau khi cài đặt QQLauncher Pro, bạn có thể thay đổi giao diện cho ứng dụng băng cách Menu/Theme và tải về giao diện ưa thích. Hiện tại, tuy số lượng giao diện cho QQLauncher Pro chưa nhiều, nhưng những giao diện này khá đẹp với phong cách trong suốt và những icon bo tròn giống iPhone.
    [​IMG][​IMG]
    Xem thêm trên Android Market:
    [URL]https://market.android.com/details?id=com.tencent.qqlauncher&feature=search_result[/URL]
    Tải về:
    [URL]http://appstore.vn/a/index.php/home/app/1610[/URL]
    Ứng dụng liên quan:
    [h=2]MIUI Launcher[/h]
    whisky_x and thieuhc like this.
  9. whisky_x
    whisky_x Thành viên
    Chỉnh sửa cuối: 19 Tháng mười một 2017
  10. Khỉ Con
    Cũng bình thường thôi bạn, ngang với Go Launcher !
