For polyurea coatings – applies up to 2 gal per minute Creative Enchitect is Graco Malaysia distributor. We distributes, repairs, and maintains Graco machines, Graco pump. Graco Reactor E-XP2 and E-XP1 proportioners are engineered to process and spray polyurea and other coatings that require high pressures. The hybrid heaters and heated hose condition the materials to the right viscosity prior to mixing. Count on Graco Reactor E-Series proportioners for power, performance and productivity on fast-curing polyurea coatings. And get the job done faster and more reliably than ever before. Graco Reactor pump E-Series Proportioners provide: Powerful hybrid heater provides up to 15,300 watts of heat to pre-heat material quickly Digital heat and pressure controls Easy to use Quick knockdown lower pumps for easy maintenance Rugged and portable Circulation valves with long-lasting seals Hose heat transformer that doesn’t require tap settings Material Plural Component Protective Coatings Polyurea Applications Ship Building & Marine Pipe and Tank Coating Wastewater Treatment Secondary Containment Spill Prevention Truck Bedliners Waterproofing Creative Enchitect (M) Sdn. Bhd. Suite 2-7-5, No. 2, 7th Floor, Wisma Menjalara, Jalan 7A/62A, Bandar Menjalara, 52200 Kuala Lumpur, Malaysia -- thiết kế văn phòng, công ty thiết kế nội thất, Loctite UV, băng keo, chống thấm bể nước thải, Máy phun thùng, chất tạo màng chống thấm, chống thấm hai thành phần, giấy nhám, chà nhám, chà nhám ướt, giấy nhám lưới, đánh bóng ghế da, sáp khử mùi nội thất, Nước lau kính, Loctite 660, Loctite 460, Loctite 603, Loctite GC 10, Chì hàn, Mỡ hàn, chống rỉ sét, Dầu chống gỉ sét, khử mùi xe hơi, Refresh Your Car, khử mùi thuốc lá, Túi thơm cho xe hơi, ecoquip 300, Máy bơm màng, băng keo dán sàn, keo dán kính xe hơi, chất tách khuôn, keo dán kim loại với nhựa, molykote, kim bơm keo, Chai xịt phòng, Invisible Glass, Loctite. băng keo chịu nhiệt, Băng keo công nghiệp, máy hút khói hàn, máy hàn chì. Graco Triton, High Pressure Pump, Dow Corning 5, Tesa Myanmar, Graco Viet Nam, Tesa tape, keo chống xoay, mỡ bôi trơn, mỡ bò, keo dán gốm sứ, keo dán cao su, dispensing pump, Graco piston pump, Graco distributor, Graco XP70… máy đánh bóng. chùi mâm xe, keo dán mạch điện, thiết kế web ngành in, vật tư y tế, băng rốn trẻ em, nhiệt kế y tế, Que đè lưỡi tiệt trùng, Alpha Chymotrypsin, Cetirizin 10 mg karaoke Kingdom, thi công nội thất biên hòa, thiết kế bar, thiết kế karaoke, thi công nội thất, thiết kế nội thất quận 2, thi công nội thất quận 2, thiết kế phòng karaoke, nội thất bình thạnh, nội thất tại Gia Lai, thiết kế nhà hàng, thiết kế pub, thiết kế lounge, thiết kế cafe, thiết kế nội thất bar,thiết kế nội thất karaoke, thiết kế nội thất cafe, kiến trúc nội thất, thiết kế nội thất cổ điển, thi công nội thất bar, thi công nội thất cafe… thi công trọn gói, xưởng gỗ, sàn gỗ cửa hàng đồ cổ. đĩa gốm Chu Đậu…
