Ripple Lock 2.5.5 - khóa máy phong cách Honeycomb
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi HuyTim, 8 Tháng tám 2011.
  1. HuyTim Sát Thủ Trên Cây Đu Đủ
    [​IMG][​IMG][​IMG]
    Requires Android:2.1 and up
    V2.0 update:
    1.add self-define shortcuts icon feature
    2.add “choose music control” setting. Now, only support “PowerAMP”
    3.add “fix power button issue” setting, solve the problem that CM7 users could not light on the screen with power button
    4.the pin input screen fixed vertical
    5.change the default “sms” in the shortcuts into “email”
    6.fix the “black background” issue. the background alpha is limited between 0-200
    7.add “self-start after root” setting. If user set the pin code, need to disable this setting
    Are you still envy of the brilliant lock screen of Android 3.0? Now, as long as your phone is Android system, you will be able to experience the beauty of the lock screen. Only use one button, you can choose to use this ripple lock screen or system default screen.
    Drag the inside circle to the outside circle can unlock screen.
    This program will continuously update and add more colorful lock screen. Please suggestions to me at any time.
    contact us, if you have any problems:
    ainanoha@163.com
    Xem thêm:
    Tải về:
  2. Khỉ Con
    Cập nhật 2.1
    What's in this version:
    1.Add widget setting item, user can add widget in lockscreen.
    2.Fix the bug that the screen will be light by volume key.
    3.Support system securiy lockscreen, such as pattern lock, password lock.
    4.Fix the bug that can not unlock screen.
  3. Khỉ Con
    Cập nhật 2.5.5
    1.display contact name and number of the incoming call
    2.add "screen timeout" setting item. users could set the timeout of the screen lock.
    3.add "screen lock sounds" setting item.
    4.add "delay lock" setting item.
    5.fix the bug, which with enough points, could not enable settings.
