RITA GO Launcher EX Theme v1
Thảo luận trong 'Android: Giao Diện, Trang Trí' bắt đầu bởi Khỉ Con, 28 Tháng chín 2012.
  1. Khỉ Con interista
    Yêu cầu phiên bản Android từ: 2.0
    Ảnh chụp màn hình:
    [​IMG][​IMG]
    [​IMG] [​IMG]
    RITA is a simple and light sketch theme designed by Artojo.
    A Pleasant Theme with an artistic touch.
    ¤ Beautiful icons
    ¤ Artisic wallpaper
    ¤ Matching Dock icons
    To Get the Chinese Painting Style Clock.
    Download and install "Go weather"
    Open Go weather Application and click menu, Chose "Theme"
    In the new window click on "widget" scroll to Chinese Painting style, click on it and apply.
    Now long press your screen, chose widget,(not go widget)
    Chose Go weather widget 4x2. that's all.
    Notice:
    GO launcher theme is only available for phones with GO Launcher EX installed.
    Search “GO Launcher EX” on Google Play Shop and install it for free.
    <----------------How to Apply the Theme--------------->
    2. after install click done.
    back to Menu -> Theme, choose Rita theme and apply it to your phone.
    <--------------- How to Change App Icons-------------->
    (Some devices might not automatically apply the icons)
    Long press an app icon -> Replace -> Theme’s icon, and then choose the icon you like.
    Thank you for your support. Feel free to contact us if you have any suggestions or wishes for other Themes.
    Xem thêm trên Play Store:
    [url]https://play.google.com/store/apps/details?id=com.gau.go.launcherex.theme.ritaa [/url]
    Tải về:
    [url]http://appstore.vn/a/index.php/home/app/10119 [/url]
