[root] Mobile ODIN Pro v3.30
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 1 Tháng chín 2012.
  1. Khỉ Con interista
    Yêu cầu phiên bản Android từ: 2.1+
    Ảnh chụp màn hình:
    [​IMG][​IMG]
    Mobile ODIN - Full firmware flashing straight from the device itself!
    Mobile ODIN is the on-device firmware flasher of choice. Just throw those firmware files on your (internal or external) SD card, start Mobile ODIN and flash away.
    !!! Your device must be rooted to be able to use Mobile ODIN. Check the list below to see if your device is supported !!!
    If you use the EverRoot option, Mobile ODIN will root the firmware while you flash it. Checking out that new leaked firmware? No reason to lose root!
    Currently supported devices:
    - Samsung Galaxy S GT-I9000/B/M
    - Samsung Galaxy S GT-I9003
    - Rogers Captivate SGH-I896
    - AT&T Captivate SGH-I897
    - Samsung Galaxy Tab 7" GT-P1000
    - Samsung Galaxy S2 GT-I9100/T
    - AT&T Galaxy S2 SGH-I777
    - Sprint Epic 4G Touch SPH-D710
    - Samsung Galaxy Note GT-N7000
    New in v2.00:
    - Samsung Galaxy S2 SHW-M250S
    - Samsung Galaxy Note GT-I9220
    - Samsung/Google Galaxy Nexus (GSM) Maguro/Yakju/GT-I9250
    - Samsung/Google Galaxy Nexus (CDMA/LTE) Toro/Mysid/SCH-I515 (no cdma radio flashing)
    - Samsung Galaxy Tab 7.7" GT-P6800/P6810
    - Samsung Galaxy 5 GT-I5500/B/L/T/M
    - Samsung Galaxy 5 GT-I5503/T
    - Samsung Galaxy 5 GT-I5508
    New in v2.10:
    - Samsung Galaxy Tab 7.0 Plus GT-P6200/P6210
    New in v2.36:
    - Samsung Galaxy S2 SHW-M250K
    - Samsung Galaxy S2 SC-02C
    New in v2.40:
    - Samsung Galaxy S2 GT-I9100M
    - Samsung Galaxy S3 GT-I9300
    New in v2.45:
    - Samsung Galaxy S2 SCH-R760 (US Cellular)
    New in v3.00:
    - Samsung Galaxy S3 GT-I9300T
    - Samsung Galaxy S3 GT-I9308
    - AT&T Galaxy S3 SGH-I747
    - Canadia Galaxy S3 SGH-I747M
    - TMOUS Galaxy S3 SGH-T999
    - Sprint Galaxy S3 SPH-L710
    - Samsung Galaxy Tab 10.1" GT-P7500/P7510
    - Samsung Galaxy Tab 2 7" GT-P3100/P3110/P3113
    - Samsung Galaxy Tab 2 10" GT-P5100/P5110/P5113
    New in v3.10:
    - US Cellular Galaxy S3 SCH-R530
    - VZW Galaxy S3 SCH-I535 (unlocked)
    - Samsung Galaxy Note GT-N7000B
    - Samsung Galaxy Note 10.1" GT-N8000
    - Samsung Galaxy Note 10.1" Wi-Fi GT-N8010/N8013
    New in v3.25:
    - Samsung Galaxy Tab 7.0 Plus GT-P6200L
    Flashing with Mobile ODIN does NOT increase your custom kernel flash counter or make the yellow warning triangle appear.
    For discussion and supporting new devices, check out the forum thread on XDA-Developers.com: http://forum.xda-developers.com/showthread.php?t=1347899
    ----- MANUAL -----
    Flashing with Mobile ODIN is easy. You start off by starting the app. The app will check your system has everything the app needs to continue (like root). It may need to download an additional package, so it is advised you have Wi-Fi available.
    Now you should see the main Mobile ODIN screen. It will list a set of partitions. Clicking a partition will allow you to select a file from your SD card to flash to that partition. Do not worry about selecting the wrong file - Mobile ODIN will not let you. Separate files (named after the partition) as well as .tar and .tar.md5 files are supported.
    From the desktop ODIN you may be used to "PDA", "PHONE", and "CSC" buttons. All three of these buttons have been replaced by the "Open file ..." button. This button will open the file you select from the SD card, and find all the partitions it can flash inside that file. So if you select a .tar file containing kernel and modem, the Kernel and Modem partitions will be set up to use that .tar file for flashing.
    Now that we have selected what we want to flash, if you have the Pro version you can proceed to the EverRoot section. The EverRoot options allows you to root your firmware while it is being flashed. Never again will you be without root! Select here which apps you want to inject in the firmware that is being flashed.
    Now that we are all done selecting partitions and configuring EverRoot, we continue to "Flash firmware". Mobile ODIN will gather all the information it needs and perform the flash. Before starting, however, it will check that your battery level is over 50%, and if applicable offer to verify MD5 checksums on the files you have selected to flash. If all is well, it will reboot into recovery mode, and flash the firmware you have selected.
    Xem thêm trên Play Store:
    [url]https://play.google.com/store/apps/details?id=eu.chainfire.mobileodin.pro [/url]
    Tải về:
    [url]http://appstore.vn/android/home/app/3455 [/url]
  2. Khỉ Con
    Cập nhật 3.30
    - Fixed: issue flashing cache partition, could corrupt entire flash
  3. oneshoot
    oneshoot Thành viên
    m110s dùng đc ko bạn ơi
