SBSH Mobile Software SafeWallet - Ví điện tử an toàn trên phone
Thảo luận trong 'ỨNG DỤNG TIỆN ÍCH' bắt đầu bởi Be Yeu, 27 Tháng mười 2009.
  1. Be Yeu Super Moderator
    SBSH Mobile Software SafeWallet v1.20 S60v3 S60v5 SymbianOS9.x Unsigned *******-TgSPDA
    Store your private information in one secure place! SafeWallet is a secure
    storage application designed to help you manage all your private
    information in one secure solution! Including a mobile version for your S60
    phone and a PC companion keeping your wallet synchronized all the time!
    Use SafeWallet to store credit cards info, passwords, bank account info
    and much more!
    The Secure Choice!
    • Store your information in Wallets protected by personal passwords and enjoy the most advanced security technologies. SafeWallet allows you to safely carry your sensitive information with you everywhere you go!
    • SafeWallet back-end engine uses powerful 256-bit AES encryption, the same encryption standard adopted by the U.S. government, along with security practices based on intelligence forces experience, providing you with the best encryption solution for your information!
    • Auto-close feature will automatically shut down SafeWallet when left unused after a user-defined time interval, making sure your wallet information will never be accessible to anyone when SafeWallet is left active
    • Ensure maximum security for your sensitive information by setting SafeWallet to close automatically when running at the background or when placing your device to the holster, making sure your information will always be kept away from unwanted eye!
    Cards and Templates
    • Create new cards based on pre-defined templates, allowing you to easily create new cards with a set of pre-defined fields configuration specifically for your card needs
    • After creation of cards based on templates the card is no longer linked to the originated template, allowing you to add, edit and remove existing fields within each of your cards based on changing demands
    • Assign icons to your cards from a large icons store with more than 240 professionally designed icons to meet your every need!
    Utilities and Features
    • Add your favorite cards to the Favorites folder and enjoy swift access to your most used cards at anytime!
    • Clean and simple interface allowing to easily create new wallets, folders and cards. Edit different items, copy passwords to your device clipboard and more!
    • Assign icons to each of your cards and folders, creating a good looking interface and easier navigation within your wallet content
    Desktop Companion
    • Enjoy full synchronization between your Windows PC and S60 device! SafeWallet Pro is shipped with a complete wallet solution for your Windows PC along with the mobile version for your S60 device!
    • Your wallets information is automatically synchronized between your SafeWallet for PC and S60 versions each time you hook your S60 device with your PC! Providing the best solution to carry your important information with you wherever you go!
    • Custom templates created using SafeWallet for PC are also automatically synchronized to your S60 version
    Download Desktop:
    http://downloads.sbsh.net/products/symbian_s60/safewallet_pro/releases/1_2/SafeWallet_Pro1_2.exe
    lamdiep, stingplv and gsm2 like this.
