Secret Video Recording Pro v1.7.5
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 10 Tháng chín 2012.
  1. Khỉ Con interista
    Yêu cầu phiên bản Android từ: 2.3.3
    Ảnh chụp màn hình:
    [​IMG][​IMG]
    One of the best Secret Recorders. Extremely easy to use. NO RECORDING LIMIT! Just click on the App's Icon to Start or Stop the Recording. No Video Picture ("preview") is shown on the screen. During Recording, the phone can be used for most other normal operation, including Game Playing, Web Browsing and Phone Calls. No Shutter Sound. High Quality Videos
    Use it to Record Videos secretly. Nobody will notice that you are recording
    This App will only work on devices with an (internal or external) SD Card, to save the Video Files on. E.g. It may not work on some Galaxy, HTC and Motorola devices. Download the Free Version of this App (SVRF), and check to see if it works on your device!
    WORKS WITH ANDROID 2.3.x, 3.x and 4.x.x
    Approx 50% of users who have bought this app, run ICS
    Use this App to Record Secret Videos of pretty girls at the beach, in business meetings, lectures, conferences, on work as a spy, etc., while browsing the web, sending messages, checking your email account, listening to music, making phone calls, and for most other purposes (except for playing or recording another Video). You can also black out (or close) the screen - if you want - without affecting the Video Recording
    This Pro version (SVRP) differs from the Free version in that there is NO RECORDING LIMIT. A Recording continues until manually stopped, as long as there is more than 500 MB free space left on your SD Card. Long Videos are divided into two or more files of 2 GB each, which is the longest Video File which can be played on Android
    FEATURES:
    - Recording starts and stops in the background
    - Records Sound and Video (using the normal, back facing camera)
    - No User Interface
    - No Configuration or Settings required
    - No additional Instructions needed (see below)
    - Just click on the Icon to Start or Stop Recording
    - Text Notifications are shown when Recording Starts and Stops
    - Click on the Status Bar Notification to see the Recorded Video(s)
    - No Video Picture ("Preview") is shown on the Screen
    - Discrete App Name and Icon
    - Installed with the Name SVRP and a common Launch Icon, to hide its real purpose
    - All Video Files are stored on the SD Card, in folder /mnt/sdcard/tmp
    (Remember to check this folder now and then, and delete the Video Files that you no longer want to keep.)
    - Video File Names start with SVR_VIDEO_, date and time, and end with .3gp
    - On a PC, Video Files can be shown by e.g. QuickTime, which can be downloaded free of charge
    - Extremely small apk-file, conserves space on your device
    ISSUES:
    - This App may not work on some devices.
    Download the Free Version of this App (Secret Video Recording Free, SVRF), and check to see if it works on your device!
    - In some countries Cameras without a Shutter Sound seem to be illegal. On devices in these countries, the Shutter Sound may be heard.
    HOW TO USE:
    1. To Start a Video Recording, click on the Icon with the Name SVRP
    A Text Notification will briefly show that the recording has Started
    While a Recording is ongoing, the word SVR is shown in the Statur Bar Notification Window (On some devices, the Recording Start Time is also shown)
    2. To Stop a Video Recording, click on the Icon again
    A Text Notification will briefly show that the recording has Stopped
    3. To See the Video, click on the Notification Text in the Status Bar, which shows that a Video File is Recorded
    4. The Video Files are stored in Folder /mnt/sdcard/tmp
    You should delete the Files that you do not want to keep (as High Quality Video Files are HUGE in size, up to approximately 1 MB per second of recording, and thus take up a lot of your precious and limited SD Card memory space)
    If you want to remove the sound and vibration which you normally hear when you touch a button, use the Menu of your device, normally found at Settings->Sound, and disable the required sounds
    If you have a problem, please report to terboel[MENTION=134938]Gmail.Com[/MENTION]
    Xem thêm trên Play Store:
    [url] https://play.google.com/store/apps/details?id=com.terboel.svrp[/url]
    Tải về:
    [url]http://appstore.vn/android/home/app/9501 [/url]
