Sense Analog Clock Widget Dark 3.2.2
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 19 Tháng chín 2011.
  1. Khỉ Con interista
    Yêu cầu: 1.5 and up
    Tổng quan: Đây là Widget đồng hồ theo phong cách Sense
    Thông tin chi tiết:
    Android Digital clock widget with Calendar, Time, System info,weather & forecast
    Sense cross Analog Dark style clock,size 4x2
    A Digital Clock widget with size 4x2
    It features:
    140 skins
    12/24 hour + Color choice on all info displayed
    System Stats Info + pop-up
    Weather & Forecast
    2 Weather layouts on clock(user choice)
    2 Forecast layouts(user choice)
    +tap bottom right->preferences
    +tap bottom left->system information dialog
    +tap weather icon->forecast
    +tap Hour->launch anything!
    +tap Minutes->launch anything!
    Widgets on Android work a bit differently than a normal application. Unlike regular programs they don't just install themselves in the application tray so you have to add them manually. They will not open or launch.
    Here's how to add a widget on your Android home screen.
    STEPS HOW TO ADD A WIDGET
    1.On your Android home screen, tap any blank or “empty” area with size 4x2 and hold down your finger.
    2.An “Add to Home screen” window will pop up. From that window, tap “Widgets”.
    3.You’ll be presented with a list of all the installed Widgets on your Android device.
    4.Select the "3D Digital Weather Clock” to add to your home screen by tapping it.
    Notes
    "Time frozen/not updating"-> taskiller killed the clock(exclude it from taskillers)
    When phone starts, clock starts in less than a min too.
    ROM users-> make sure the clock is NOT moved on SD card.
    Widgets are not supposed to be on SD card. Move it back to the phone storage.
    Weather hint: For world destinations with two words in the name, type in the box the words with a plus sign.
    For example "Buenos Aires" type "Buenos+Aires",remember the "+" sign -no spaces, don't include the quotes.
    Email problems/suggestions
    Check our website for more help.
    EXCLUDE IT FROM TASKILLERS!!!
    Be polite, this is a free app :)
    Xem thêm trên Market:
     https://market.android.com/details?id=factory.widgets.SenseClockDark&feature=search_result
    Tải về:
    [url]http://appstore.vn/a/index.php/home/app/1892 [/url]
  2. Khỉ Con
    3.2.2
    What's in this version:
    1. [fix] simple forecast screen error.
    2. [fix] wake up refresh on some phones.
