Shake Phone - Lắc điện thoại là đổi bài hát.
Thảo luận trong 'ỨNG DỤNG TIỆN ÍCH' bắt đầu bởi tichau, 22 Tháng mười 2010.
  1. tichau Guest
    Shake Phone v2.50 S60v5 SymbianOS9.4 Unsigned "shake phone to change song and menu"
    After watching some videos on youtube that sonyericcson as a function of the music player Shake control (change song by shaking the phone) and noticed that my 5800 could not have decided to create an application that implements the Shake Control feature in symbian accelerometer .​
    The program (still BETA)
    Allows mainly going for a song simply shake the phone
    The beta but it works in all menus of all programs (this part will be finished in vesione stable).
    Also from the program you will:​
    - Enable or Disable the shake (the opening is activated by default)
    - Set the direction of the shake: Right or Left (for profit or to scroll through songs contacts and sms)
    - Set the delay: The time between recognition of a shake and another.
    - Set the detection sensitivity of the shake​
    The program consists of 2 parts:​
    Shake-Control: The core of the program, install it first but did not start it
    Shake-Phone: The interface (Start menu just this phone).​
    To operate, open the music player, start the program and set the settings to your liking.
    Back then in the music player and you just shake the phone to change song​
    I remember that it is a BETA program therefore still far from being a stable and functional, with your feedback we can improve a lot​
    Change Log :
    # Added two new directions for the shake: up and down, help you through the phonebook.
    # Added support for Nokia C6-00
    # Added support for CFW OF C6-00 on Nokia 5800/5530
    # Added German translation
    # Reduced the RAM consumption
    # Reduced the size of the resource file, taking up less space in c:
    Download
    Funny_clock, dungmisa, kijuto and 2 others like this.
  2. key12345
    key12345 Thành viên
    cài rồi mà lắc tay đổi nhạc kg được bạn ơi
  3. tichau
    tichau Guest
    N97 cài trên ổ C và lắc => đổi nhạc :D.
  4. tichau
    tichau Guest
    Shake control/Phone v2.60 S60v5/^3 SymbianOS 9.x Unsigned
    Shake control to change music, just shake the phone and the music changes!
    Functions-
    - It mainly allows to go forward one song. Just shake your phone.
    - Enable or disable the Shake. The opening is activated by default.
    - Set the direction of the Shake . Right or Left.
    - Set the Delay. The time between recognition of a shake.
    Released 16/02/2011
    ChangeLog:
    Reduced the size of the resource file, taking up less space in c: (50 kb less about)
    Added support for Nokia N8
    Grouped and reorganized the menu (Settings)
    Added the function to use Phone Shake the keypad is locked (you can choose whether or not an option)
    Improved help (from now on will be online)
    dinhvandaidk thích bài này.
  5. vnt1369
    vnt1369 Thành viên
    PM này cài trên ổ C hay trên thẻ nhớ vậy chủ thớt, e cài trên thẻ nhớ nhưng kg đổi được?
  6. hangdoc
    hangdoc Thành viên
    sao em ko dùng trên vivaz pro dc vậy bác
  7. tuanhanh
    tuanhanh Thành viên
    cảm ơn bác nhé.em test thử đã,hehe
