1.Accelerometer sensitivity patch - Calculate more accurate values will increase reliability. ※Sensor values will be initialized after the update. You need must re controll sensor value 2.Proximity sensors set the patch - Proximity of the minimum and maximum settings, semi-automatically help - All devices can be equipped with proximity sensors work - A fixed value that does not work because the existing patches for the device ※Manually input does not guarantee normal operation. Please note the benefits. 3.Vibration sensor alerts recognition 4.Virtual Phone Sensor Test ● This application features 1. Receive the Phone with shake 2. Disconnect the Phone with shake 3. Receive the Phone to Proximity Sensor 4. Hang up correction to Proximity Sensor 5. Virtual Phone Sensor Test 6. Set semi-automatic sensor 7. Toast message alerts 8. Vibration alert sensor recognition ▼How to Use When a phone call. you just shake the phone! Also, you want to hang up. you just shake the phone! When using the first sensitivity control is essential! ▼this app's merit 1. Very light 2. Very simple 3. Can easily take the call 4. Can easily hang up the call 5. Free App! Xem thêm: Mã: https://market.android.com/details?id=com.ysrsoft.shakecall&feature=search_result Tải về: http://appstore.vn/a/index.php/home/app/2372
