Smart Taskbar Pro 1.2.0a - thanh tác vụ thông minh cho Android
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 9 Tháng chín 2011.
  1. Khỉ Con interista
    Đây là thanh tác vụ thông minh, giúp bạn truy cập mọi ứng dụng chỉ với 1 lần chạm.
    Feature
    *Build custom action (Need Pro)
    Smart Taskbar doesn't just launch your installed APP, but also builds any combination of action such as direct phone call to someone or go to your bookmark for super fast without going back to home operation.
    *Super fast launcher
    Smart Taskbar is exceptionally designed to use your phone's CPU efficiently. The result is a super smooth and fast switching experience.
    *5 quick launch spots (10 Spots in Pro Version)
    Store your favorite apps or shortcut in any of the five spots for 2 steps instant access.
    *Multi Tasker (multitasking)
    Navigate to TASK label to see recent/running app in no time.
    *Task killer (need pro)
    Smart Taskbar also does task killer function to a more direct and intuitive level. Just click on any of the running app and it will be stopped instantly.
    *App organizer
    Your phone is packed with hundred of APPS? Use Smart Taskbar to create label to group them by function/usage/location.. whatever you like.
    *Widget
    Smart Taskbar takes widget support differently. Instead of showing your widget to Home screen, you use widget in Smart Taskbar just like launching a regular App. It is very convenient if you have too many widgets to show or you want higer security by not letting people easily see your social widgets at Home screen.
    *Quick uninstaller
    Quickly uninstall any installed app with just one finger click. No more walk through native Android settign trees for just a simple app uninstall action.
    *Quick App setting management
    One click to go to App info page for, super fast clear cache, clear data, force stop, and uninstall.
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    Xem thêm:
    https://market.android.com/details?id=com.smart.taskbar&feature=search_result
    Tải về:
    Smart Taskbar
    http://appstore.vn/a/index.php/home/app/681
    Smart Taskbar Prokey
    http://appstore.vn/a/index.php/home/app/2646
  2. Khỉ Con
    1.1.11
    Added
    (1) Home plug in integration
  3. Khỉ Con
    What's in this version:
    1. V1.2.0a
    2. Changed:
    3. (1) Default theme to HC
    4. (2) Updated More app
    5. (3) Bug fix
