Best TaskMan shows comprehensible information about programs and processes running on the device. Unlike built-in task switcher it tells you exactly what programs are running on your smartphone and it gives you answers to the obvious ensuing questions, such as where these programs reside, memory they consume and what capabilities they use. Features include: * Task list * Memory View * Quick start functionality * Integration to the system and customizable activation * Overview and control running applications * Ability to exclude applications from tasks list * Ability to close or kill an application * Customizable 'close all' command * Detailed information about each running application * Overview and control running processes * Ability to close or kill a process * Overview of the list with installed applications
Smartphoneware Best TaskMan v3.00 Symbian^3 incl ......-HSpda Best TaskMan shows comprehensible information about programs and processes running on the device. Unlike built-in task switcher it tells you exactly what programs are running on your smartphone and it gives you answers to the obvious ensuing questions, such as where these programs reside, memory they consume and what capabilities they use. In addition to that you can switch between running applications, close unneeded ones, launch your favorite applications fast (quickstart) or go deeply with enhanced process viewer and installed applications list. If you really want to know what's behind of the screen of your device and want to control it then Best TaskMan is the application for you. Features include: * Task list * Memory View * Quick start functionality * Integration to the system and customizable activation * Overview and control running applications * Ability to exclude applications from tasks list * Ability to close or kill an application * Customizable 'close all' command * Detailed information about each running application * Overview and control running processes * Ability to close or kill a process * Overview of the list with installed applications
