Smartphoneware Screen Snap v2.00 S60v3 SymbianOS9.x Signed Freeware With Best ScreenSnap you can capture screenshots on your smartphone, save them to a file or send them to friends or to your desktop computer. Best ScreenSnap is FREE! You can download and use it absolutely free of charge. No spyware or adware inside. Features include: * Configurable hotkey to make a screenshot. * Sound notification after taking screenshot * Supports true colour BMP, 256 colour BMP, and JPG * Ability to send image via Bluetooth, Infrared, MMS or email. * Auto-generated image name. * Ability to set up where to save screenshots. What's new in version 2.00: * Problem with screen orientation change is fixed * Delay option added * Green key press to take screenshot is added (to work with delay option) * Camera sound volume is taken from profiles now * Help option added * Shift+arrows key combination are disabled (compatibility issues) * Small UI cosmetic changes
Smartphoneware Best Screen Snap v3.00 S60v3/S60v5 SymbianOS9.x Signed With Best ScreenSnap you can capture screenshots on your smartphone, save them to a file or send them to friends or to your desktop computer. Best ScreenSnap is FREE! You can download and use it absolutely free of charge. No spyware or adware inside. Features include: * Configurable hotkey to make a screenshot. * Sound notification after taking screenshot * Supports true colour BMP, 256 colour BMP, and JPG * Ability to send image via Bluetooth, Infrared, MMS or email. * Auto-generated image name. * Ability to set up where to save screenshots. P.S : There is no change log available...
