SmartWorkspace 0.4 With out Sensor S60v3 Unsigned English Updating an interesting program that allows you to display on your desktop smartphone standby additional application icons. Key features: - Additional applications for quick launch (no limit on the number) - Activation / deactivation of the program by pressing the specified key (now it is the default button "Clear") - All icons are taken from the theme New in this version: - Full support for touch screens, - Instant hiding (in the transition from the desktop to any other application), - Fixed a bug where if the freezing keyboard bar did not intercept the keys - Minor bug fixes ... The program is no interface and all settings are carried out manually through the file!: / Private/eacceee1/Settings.ini (instructions for working with the program -!: / Private/eacceee1/Using SETTINGS.INI. Txt). SmartWorkspace 0.4 without sensor - version for models in which to install the basic version error!
anh ơi ko hướng dẫn gì làm sao bọn em hiểu, tiếng Anh e đọc thì có hiểu nhưng ko biết thao tác với cái file txt đấy thế nào cả. hix. Mong đại ca chỉ giáo.
