SmartWorkSpace v0.2b EN
Thảo luận trong 'ỨNG DỤNG TIỆN ÍCH' bắt đầu bởi verylove, 13 Tháng mười hai 2009.
  1. [​IMG]
    software description:
    English name: SmartWorkspace Chinese name: Smart navigation bar
    software version: 0.2b
    Authors: kvet
    test models: N81
    theoretical support: S60V3 All models, 5th edition please self-test
    Software Tip: Click on the icon hidden in the background automatically switch the default hotkey for the delete key
    update:
    1. FP2 models support
    2. Support free to adjust the navigation bar displays the location and height (vertical & horizontal screen display
    3. Support the addition of number of shortcuts, the default is 6
    problem fixed:
    1. Exit displayed when KERN-EXE C3 error
    2. Click to hide programs automatically
    This helps you to configure smartworkspace bar like icons, size and position.
    Location of configuration file is !:\private\eacceee1\Settings.ini.
    Editor Tool: Use X-plore to edit Settings.ini file. Just press "8" key on highlighting the file.
    Changing Icons: to change icons just replace or add uid under [MBApplications], Place uids in the order in which you like the icons to be. You can place as many icons you like.
    How to get uid: you need JBAKTASKMAN, just open the program that you want to add to the list, and them in to JBAKTASKMAN and highlight the app then go to menu>task info and you will see the the there.
    Change Shortcut key: the hotkey for activating and deactivating the onscreen bar can be changed by changing the keycode under [MBSettings] just write the appropriate key code. By defaul the hotkey is "C" or delete key, At the end of this file you can see some common keycodes.
    Change position : the onscreen position can be customised under [MBSettings], you can choose between OnCBA, aboveCBA or add any numeric value on the y axis depending upon your phones resolution. For example entering 45 will place the bar 45 pixels above the bottom line.
    Change height : the height or the vertical size of the bar can also be customised under [MBSettings], you can select between NormalHeight, DoubleHeight or enter any numeric value as per you phones resolution.
    Position and Height can be customised seperately for portrait and landscape mode. Just place the value as per your choice.
    Here is list of various input that can be used under each option.
    [MBApplications] place uid here
    [MBSettings] program settings.
    KeyCode = enter keycode here
    PortraitPosition =
    PortraitHeight =
    LandscapePosition = LandscapeHeight =
    KeyCode = value for keycode
    key = keycode
    1 = 49
    2 = 50
    3 = 51
    4 = 52
    5 = 53
    6 = 54
    7 = 55
    8 = 56
    9 = 57
    0 = 48
    * = 42
    # = 35
    back = 63497
    next = 63498
    left = 63496
    right = 63495
    left soft key = 63554
    right soft key = 63555
    delete = 8
    dial key = 63586
    hang up key = 63585
    values for position :
    1. OnCBA : cover left and right buttons
    2. AboveCBA : left and right buttons not covered
    3. any numeric value
    values for Height:
    1. NormalHeight
    2. DoubleHeight
    ishjda thích bài này.
