Sn0wbreeze Update Here Tạo Firmware Custom cho iPhone
Thảo luận trong 'Firmware - Jailbreak - Unlock' bắt đầu bởi punlinh2007, 12 Tháng mười một 2012.
  1. punlinh2007 Never Ending Dreams
    What is New?
    Added 6.0 (10A403)/6.0.1 (10A523) support. (Only includes iPhone 3GS & A4 devices).
    The 6.0/6.0.1 is currently a tethered based jailbreak via iBooty (except for iPhone 3GS old bootrom users).
    SAM is built-in for iOS 6 hacktivations. (Hacktivated phones can reboot to a semi-tethered state after being activated [rather than just hang at the Apple Logo]). Kudos @sbingner!
    Downgrading:
    Use iFaith mode after selecting/downloading the appropriate IPSW for your device. You will then be prompted to browse for SHSH blobs for the IPSW you have selected.
    Remember to enter a PWNED DFU state with sn0wbreeze's iREB button in the top bar of sn0wbreeze prior to (SHIFT + Restoring) the custom signed IPSW!
    iREB & iOS 6:
    Due to some changes in iOS 6, the current public standalone version of iREB will NOT enter a proper PWNED DFU state for restoring to custom iOS 6 IPSWs. An update for the standalone version should come sometime this week. In the meantime, use the iREB tab located in sn0wbreeze's top status bar to enter a proper PWNED DFU state.
    A5(X)/A6(X) Support?:
    As stated many times in the past, sn0wbreeze cannot be updated to work on A5(X)/A6(X) devices until a low level exploit in DFU or iBoot is found and made public.
    A5(X)/A6(X) Baseband Preservation/Hacktivation?
    For those running A5(X)/A6(X) devices and need to preserve your baseband, there is nothing you can do at the moment. For those wanting to hacktivate, the only advice I can give is to buy the carrier's SIM (the one its locked to obviously) on ****. The SIM does not have to be active with the carrier to activate the phone.
    Known Bugs/Issues:
    Windows 8 users currently need to use this NET Framework to run sn0wbreeze.
    iPad baseband will fail to flash on iOS 4.0 --> iOS 4.2.1 restores.
    [B][FONT=Arial][URL="http://cloud.github.com/downloads/iH8sn0w/sn0wbreeze/sn0wbreeze-v2.9.7.zip"]SNOWBREEZE 2.9.7[/URL][/FONT][/B]
  2. quykhanh53
    quykhanh53 Thành viên
    Hướng dẫn Jailbreak bằng tool Sn0wbreeze v2.9.7 cho iOS 6 / iOS 6.0.1 với các thiết bị Pre-A5
    Phiên bản cập nhật Sn0wbreeze v2.9.7, hỗ trợ cho iOS 6 / iOS 6.0.1 các thiết bị Pre-A5 như iPhone 4, iPhone 3GS và iPod touch thế hệ thứ 4.
    Thực hiện theo từng bước dưới đây để đạt được một tethered jailbreak iOS 6.0.1 bằng cách sử dụng công cụ Jailbreak Sn0wbreeze cho Windows. Trước khi thực hiện bạn nên nhớ đây chỉ là một jailbreak tethered.
    Xem video hướng dẫn
    Ngoài ra, bạn cũng có thể sử dụng Redsn0w của Dev Team iPhone để jailbreak 6.0.1 trên các thiết bị A4 gồm iPhone và iPod touch.
    Thiết bị hỗ trợ: Jailbreak này chỉ tương thích với các thiết bị pre-A5 như iPhone 3GS, iPhone 4 và iPod touch thế hệ thứ 4. nó sẽ không làm việc trên bất kỳ các thiết bị mới hơn.
    Làm thế nào để jailbreak iOS 6.0.1:
    Bước 1: Tải phiên bản mới nhất của Sn0wbreeze ( từ đây ) cho Windows và lưu các tập tin ở một vị trí quen thuộc trên máy tính của bạn.
    Tải về iOS 6.0.1 cho thiết bị của bạn.
    Bước 2: Kết nối thiết bị iOS với máy tính bằng cáp USB.
    Bước 3: Chạy ứng dụng Sn0wbreeze trên máy tính Windows của bạn.
    Lưu ý: người sử dụng Windows 8 cần phải tải về và cài đặt Microsoft NET Framework 3.5, theo các bước được ghi chi tiết ở đây.
    Bước 4: Click vào nút mũi tên màu xanh bên cạnh để tiếp tục. Chọn Browse cho IPSW, chỉ vào Sn0wbreeze để chọn tập tin firmware thích hợp với iPhone của bạn.
    Bước 5: Chọn Simple Mode từ danh sách có sẵn các chế độ và tiếp tục nhấn vào nút kế tiếp để tạo một custom firmware tùy chỉnh. Sn0wbreeze sẽ tạo ra một tập tin firmware được xây dựng tùy chỉnh. Khi hoàn tất, tập tin firmware được tạo nằm trong máy tính của bạn.
    Bước 6: Màn hình tiếp theo với 4 lựa chọn - iFaith Chế độ, chế độ Simple Mode, chế độ Expert Mode và chế độ bảo quản Baseband.
    • iFaith Mode: chế độ này cho phép bạn tạo ra một tùy chỉnh ipsw chứa SHSH đã lưu trước đó (có ích khi downgrading).
    • Simple Mode: chế độ này tự động tạo iOS 6.0/6.0.1 tùy chỉnh IPSW của bạn mà không lựa chọn bất kỳ tùy chọn tùy chỉnh.
    • Expert Mode: Ở chế độ này cho bạn nhiều cách tùy chọn để Jailbreak trước khi tạo IPSW tùy chỉnh iOS 6.0/6.0.1.
    • Baseband Preservation Mode: Chế độ này chỉ có ích nếu bạn muốn nâng cấp firmware latest6.0/6.0.1 mà không nâng baseband lên và không Jailbreak iPhone của bạn.
    Trong trường hợp này, bạn chọn chế độ Expert Mode.
    Lưu ý: Sn0wbreeze sẽ không bao giờ cập nhật baseband iPhone của bạn bất kể bạn chọn chế độ nào.
    Bước 7: Màn hình kế tiếp để bạn sẽ bắt đầu quá trình tùy biến.
    Nhấp vào nút General để bắt đầu.
    Bước 8:Trong màn hình General, có một loạt các tùy chọn để tùy chỉnh Jailbreak của bạn.
    • Enable Battery-Percentage: Tùy chọn này sẽ thêm số tỷ lệ phần trăm nhỏ bên cạnh biểu tượng pin (trong thanh trạng thái).
    • Activate The iPhone [hacktivate]: Tùy chọn này sẽ kích hoạt iPhone của bạn, nếu bạn muốn unlock.
    • Install SSH: Tùy chọn này cài đặt dịch vụ SSH cho phép bạn xem hệ thống iDevice của bạn.
    • Root Partition Size: Tùy chọn này sẽ thay đổi kích thước phân bổ vào các ứng dụng Jailbreak. Chúng tôi khuyên bạn nên để nó ở kích thước mặc định.
    Chọn chế độ bạn muốn áp dụng cho Jailbreak của bạn và sau đó nhấp vào mũi tên màu xanh.
    Bước 9: Màn hình tiếp theo cho phép bạn cài đặt trước các ứng dụng bên thứ 3 application/ tweaks . Nếu bạn muốn cài đặt và chọn chúng. Tiếp theo nhấp vào mũi tên màu xanh.
    Bước 10: Bây giờ bạn trở lại màn hình tùy chỉnh một lần nữa.
    Chọn Build IPSW và nhấn vào mũi tên màu xanh để tiếp tục quá trình tạo IPSW.
    Bước 11: Sn0wbreeze sẽ bắt đầu tạo IPSW tùy chỉnh với các tùy chọn mà bạn đã chọn. Quá trình này có thể mất từ ​​5 - 30 phút tùy thuộc vào tốc độ của máy tính của bạn. Một khi tập tin firmware được tạo ra trên màn hình desktop của máy tính của bạn.
    Bước 12: Sau khi Sn0wbreeze tạo ra IPSW tuỳ chỉnh của bạn, bạn cần phải đặt iDevice của bạn vào chế độ DFU. Để bắt đầu quá trình này nhấn vào nút OK.
    Khi bạn nhấp vào nút OK, vào chế độ DFU để bạn có thể restore lại tập tin firmware IPSW của bạn tùy chỉnh.
    Bước 13: Sau khi làm theo đúng với hướng dẫn của Sn0wbreeze, khởi động iTunes, bạn sẽ được Sn0wbreeze nhắc nhở iReb chạy thành công, bạn quay trở lại iTunes và nhấp SHIFT + Restore. Chọn tập tin firmware IPSW tùy chỉnh của bạn (nằm trên desktop máy tính của bạn) để restore iPod, iPhone hoặc iPad của bạn.
    Bước 14: Jailbreak iOS 6./6.0.1 này là tethered, bạn cần phải khởi động iPhone, iPod Touch hoặc iPad bằng cách sử dụng một công cụ gọi là iBooty . Ngoài ra, bất cứ lúc nào bạn khởi động lại thiết bị iOS của bạn, bạn cần sử dụng công cụ này.
    Lưu ý: iBooty sẽ được trích xuất vào máy tính của bạn một khi bạn đã tạo ra một tập tin firmware iOS tùy chỉnh 6./6.0.1 qua Sn0wbreeze v2.9.7.
    iBooty trong thư mục desktop trên máy tính của bạn và nhấp chuột vào iBooty.exe để khởi động iBooty.
    Một thông báo được đưa ra và sau đó bạn sẽ được đưa đến một màn hình được mô tả dưới đây ...
    Bước 15: Từ đây chỉ cần chọn iDevice của bạn từ danh sách thả xuống.
    Khi lựa chọn iDevice của bạn click vào nút Start.
    Đưa iDevice của bạn vào chế độ DFU và iDevice của bạn sẽ khởi động trong trạng thái Jailbreak.
    Sau khi khởi động vào chế độ tethered, bạn có thể chạy Cydia và bắt đầu cài đặt tinh chỉnh và ứng dụng ưa thích của bạn!
    Cydia chạy trên iOS 6.0.1​
    Bạn có một Jailbreak tethered iOS 6.0.1 bằng cách sử dụng công cụ Sn0wbreeze. Lưu ý. Do tính chất là tethered jailbreak, vì một lý do nào đó mỗi khi bạn tắt hoặc khởi động thiết bị, bạn phải khởi động iPhone bằng iBooty.
    Trích dẫn từ Redmond Pie.
  3. punlinh2007
    SNOWBREEZE 2.9.8
    Downgrading:
    For those running A5(X)/A6(X) devices and need to preserve your baseband, there is nothing you can do at the moment. For those wanting to hacktivate, the only advice I can give is to buy the carrier's SIM (the one its locked to obviously) on ebay. The SIM does not have to be activated with the carrier to activate the phone.
    Known Bugs/Issues:
    Windows 8 users currently need to use this workaround to run sn0wbreeze.
    First boot on an AppleTV 2 for 5.1/5.2 firmwares has funky glitches. Should be fixed by updates pushed via repos.
    iPod Touch 2G 4.x.x restores fail (fix coming soon).
    [CODE][B][URL="https://nodeload.github.com/iH8sn0w/sn0wbreezedl/zip/master"]DOWNLOAD SNOWBREEZE 2.9.8[/URL][/B]
    [/CODE]
  4. punlinh2007
    sn0wbreeze v2.9.9
    DOWNLOAD
    binhnv143 thích bài này.
  5. punlinh2007
    sn0wbreeze v2.9.10 (3.1.3 -- 6.1.2 )
    iH8Sn0w has update to Sn0wBreeze 2.9.10 brings support for jailbreaking iOS 6.1 untethered jailbreak. Sn0wbreeze 2.9.10 supports all A4 devcies and iPhone 3GS on iOS 6.1.2 and Apple TV 2 iOS 5.2. You can download Sn0wbreeze v2.9.10 from the links below. This tools has fixed issue sandbox fix Apple TV 2 iOS 5.2 and added iOS 6.1.2 support for 3GS/A4 devices.
    Download Sn0wbreeze 2.9.10
  6. jevintran
    jevintran Thành viên
    tạo fw custom 6.x khi restore bị lỗi rơi vào SOFT DFU bác punlinh2007, 3gs lock 6.15, anh em nào trong trường hợp giống mình thì cẩn thận
  7. bintuananh
    bintuananh Thành viên
    đã có [h=2]sn0wbreeze v 2.9.11[/h]
    Tình hình là vừa buil bản fw custom 6.1.2 cho 3gs bb 5.13.07 chạy thấy ổn, mà bản fw này đã có sẵn e 1.4 jb luôn chưa cần active. rất tiện ạ ! Thanks sn0wbee, hihi .
    binhnv143 and audiv8 like this.
  8. punlinh2007
    sn0wbreeze v2.9.13 Get Updated, Fixed IPhone3,2 Limera1n Injection Issues
    News:
    Ugh. More rootfs bug fixes.
    Support: 3x --- 6x
    [B][FONT=Arial][URL="https://github.com/iH8sn0w/sn0wbreezedl/archive/master.zip"]Download Snowbreeze v2.9.13[/URL][/FONT][/B]
  9. intershop
    intershop Thành viên
    các bro cho em hỏi em làm theo đúng y chang nhưng sau khi resdtore iphone ở chế độ dfu màn hình đen thui. em chỉ thành công trên 5.1.1
  10. punlinh2007
    sn0wbreeze v2.9.14
    sn0wbreeze v2.9.14 released with 6.1.3 support
    What is New?
    2.9.14:
    After Cydia's mishap with aptickets from 6.0 --> 6.1.2 (causing soft-dfu loops), sn0wbreeze now includes an apticket validation. It will verify the apticket after browsing for iOS5+ blobs in iFaith mode.
    : Added tethered support for A4 devices on iOS 6.1.3 (3GS old bootroms are untethered as usual).
    [B][URL="http://www.mediafire.com/?cqj19ajrqcfv18j"][FONT=Arial]Link Mediafire 2.9.14[/FONT][/URL][/B]
