So sánh Loại, tốc độ CPU các Nokia Symbian
Thảo luận trong 'S60/S80/S90: KIẾN THỨC & KINH NGHIỆM' bắt đầu bởi vietkim, 22 Tháng hai 2007.
  1. vietkim <b>Google MẸO</b>
    Model | Type | Processor | Architect| Speed
    Nokia 9210 RAE-3(N); 32-bit RISC CPU ARM-9 52 MHz
    Nokia 9210c RAE-3(N); 32-bit RISC CPU ARM-9 52 MHz
    Nokia 9210i RAE-5(N); 32-bit RISC CPU ARM-9 52 MHz
    Nokia 9290 RAB-3(N); 32-bit RISC CPU ARM-9 52 MHz
    Nokia 3600 NHM-10 32-bit RISC CPU ARM-9 104 MHz
    Nokia 3620 NHM-10(X); 32-bit RISC CPU ARM-9 104 MHz
    Nokia 3650 NHL-8 32-bit RISC CPU ARM-9 104 MHz
    Nokia 3660 NHL-8X 32-bit RISC CPU ARM-9 104 MHz
    Nokia 6600 NHL-10 32-bit RISC CPU ARM-9 104 MHz
    Nokia 7650 NHL-2(NA); 32-bit RISC CPU ARM-9 104 MHz
    Nokia N-Gage NEM-4 32-bit RISC CPU ARM-9 104 MHz
    Nokia N-Gage QD RH-29 32-bit RISC CPU ARM-9 104 MHz
    Nokia N-Gage QDA RH-47 32-bit RISC CPU ARM-9 104 MHz
    Nokia 3230 RM-51 32-bit RISC CPU ARM-9 123 MHz
    Nokia 6260 RM-25 32-bit RISC CPU ARM-9 123 MHz
    Nokia 6670 RH-67 32-bit RISC CPU ARM-9 123 MHz
    Nokia 6670B RH-68 32-bit RISC CPU ARM-9 123 MHz
    Nokia 7610 RM-51 32-bit RISC CPU ARM-9 123 MHz
    Nokia 7610B RH-52 32-bit RISC CPU ARM-9 123 MHz
    Nokia 6620 NHL-12 32-bit RISC CPU ARM-9 150 MHz
    Nokia 7710 RM-12 32-bit RISC CPU ARM-9 150 MHz
    Nokia 9300 RAE-6(N); TI OMAP 1510 ARM-925 150 MHz
    Nokia 9300B RA-4 TI OMAP 1510 ARM-925 150 MHz
    Nokia 9300i RA-8 TI OMAP 1510 ARM-925 150 MHz
    Nokia 9500 RA-2 TI OMAP 1510 ARM-925 150 MHz
    Nokia 9500B RA-3 TI OMAP 1510 ARM-925 150 MHz
    Nokia 770 SU-18 TI OMAP 1710 ARM-926 220 MHz
    Nokia 6630 RM-1 TI OMAP 1710 ARM-926 220 MHz
    Nokia 6680 RM-36 TI OMAP 1710 ARM-926 220 MHz
    Nokia 6681 RM-57 TI OMAP 1710 ARM-926 220 MHz
    Nokia 6682 RM-58 TI OMAP 1710 ARM-926 220 MHz
    Nokia E50-1 RM-170 TI OMAP 1710 ARM-926 220 MHz
    Nokia E50-2 RM-171 TI OMAP 1710 ARM-926 220 MHz
    Nokia E60 RM-49 TI OMAP 1710 ARM-926 220 MHz
    Nokia E61 RM-89 TI OMAP 1710 ARM-926 220 MHz
    Nokia E62-1 RM-88 TI OMAP 1710 ARM-926 220 MHz
    Nokia E62-1 RM-88A TI OMAP 1710 ARM-926 220 MHz
    Nokia E70-1 RM-10 TI OMAP 1710 ARM-926 220 MHz
    Nokia E70-2 RM-24 TI OMAP 1710 ARM-926 220 MHz
    Nokia N70-1 RM-84 TI OMAP 1710 ARM-926 220 MHz
    Nokia N70-5 RM-99 TI OMAP 1710 ARM-926 220 MHz
    Nokia N71-1 RM-67 TI OMAP 1710 ARM-926 220 MHz
    Nokia N71-5 RM-112 TI OMAP 1710 ARM-926 220 MHz
    Nokia N72-5 RM-180 TI OMAP 1710 ARM-926 220 MHz
    Nokia N73-1 RM-133 TI OMAP 1710 ARM-926 220 MHz
    Nokia N73-? RM-132 TI OMAP 1710 ARM-926 220 MHz
    Nokia N80-1 RM-92 TI OMAP 1710 ARM-926 220 MHz
    Nokia N80-3 RM-91 TI OMAP 1710 ARM-926 220 MHz
    Nokia N90-1 RM-42 TI OMAP 1710 ARM-926 220 MHz
    Nokia N91-1 RM-43 TI OMAP 1710 ARM-926 220 MHz
    Nokia N91-5 RM-158 TI OMAP 1710 ARM-926 220 MHz
    Nokia N92 TI OMAP 1710 ARM-926 220 MHz
    Nokia N93-1 RM-55 TI OMAP 2420 ARM-11 330 MHz
    Nokia N93-5 RM-153 TI OMAP 2420 ARM-11 330 MHz
    http://vietkim99.googlepages.com
    molotok, Daddy, anhbida and 18 others like this.
  2. nickcarter_online
    nickcarter_online Thành viên
    Thanks bác đã cho những thông số rất quý giá . Thế bác lấy cái này ơ nguồn nào vậy ?
    RyanTom8891 thích bài này.
  3. vietkim
    Có j đâu mà ... quý hihihi. Mình tình cờ search trên mạng, giờ chẳng nhớ ở đâu nữa,
    (Thanks thì chỉ cần bấm nút thanks thui ah, MOD sẽ nhắc đó)
    RyanTom8891 and roykeane like this.
  4. luke8x
    luke8x Thành viên
    thanks vietkim nhiều nha. không biêt còn mấy con khác thì sao nữa ?
  5. anhbida
    anhbida Thành viên
    chưa thấy cập nhật N95 và N93i.
  6. tccdthuan
    tccdthuan Guest
    sao mình thấy N93-1 RM-55 TI OMAP 2420 ARM-11 330 MHz và N70-1 RM-84 TI OMAP 1710 ARM-926 220 MHz rõ ràng thì tốc độ xử lý của N93 thì nhanh hơn 1/3 lần nhưng khi mình cầm lên Í là khi intall các phần mềm thì con N70 nó nhanh hơn nếu mình nâng lên N70ME thì nó còn xử lý nhanh hơn nữa
    mà mình nghĩ khi nâng lên N70ME thì khi đó nó còn chứa thêm nhiều file o hệ thống nhưng nó lại chạy nhanh hơn ban đầu nữa
    có bạn nào hiểu thì giải thích giùm mình dc k?
    thanks
  7. giangnt1987
    giangnt1987 Thành viên
    Sao ko thấy có dòng máy 6708 vậy bạn.Mình cũng đang muốn thử so sanh xem nó thế nào.Mà có ai biết những thông số này nó nói lên cái j ko vậy minh chỉ cảm nhận lơ mơ là cái nào có MHZ cao là chạy nhanh hơn thôi còn lại nhìn chẳng hiểu j cả
  8. batmanhuy
    batmanhuy Thành viên
    ko bít con SAMSUNG D720 CỦA EM TỐC ĐỘ BI NHIU NHỈ?MÁY DÙNG HDH S60 OS7
  9. Bao_Phong
    Bao_Phong Thành viên
    Bạn mà nâng N70 ME lên là chạy có khác đó bạn,hồi lần trước mình kô dám lên nhưng thấy ghiền ghiền muốn tìm hiểu và xài thử tai nghe Express Control của 3250 nên lên thử,lên rùi chạy mới biết là "Tê".Quá tuyệt luôn
  10. nantoan
    nantoan Thành viên
    Tui xin gop ý như sau:
    - N73 có tốc độ CPU là 206 Mh chứ kg phai 220 Mh.
    - N95 là 206 Mh
    Cai này xem trong phần Info phone, các bạn xem đúng kg nhé.
