Softbank summer colection 2008 !!!!!!!!!!!! HOT
Thảo luận trong 'JMP: Tin Tức, Đánh Giá' bắt đầu bởi Elvis Le, 3 Tháng sáu 2008.
  1. Elvis Le Thành viên
    Đây là bộ sưu tập softbank hè 2008, mời anh em thưởng thức nhưng kiệt tác lay động mọi giác quan Y_Y
    - SHARP 923SH: It’s equipped with a 3.3'' AQUOS ASV Fullwidescreen in VGA resolution (854x480), a 5.2Megapixels a camera with a CMOS sensor AF, a GPS, a 1Seg tuner, a microSDHC slot (up to 4GB), and Bluetooth. Otherwise, concerning functionalities, it features a TouchCruiser sensor, a system allowing you to move around the screen without passing through the directional pad and the Video recorder function. And, our phone is compatible with W-CDMA (Japanese networks), GSM (900/1800/1900MHz), 3G.
    - SHARP 824SH PREMIUM WATERPROOF: Equipped with a 2.8'' ASV Widescreen ASV in QVGA resolution (400x240), a 2Megapixels camera AF, a 1Seg tuner, the Bluetooth and a microSDHC slot (Up 4GB). It is W-CDMA (Japanese networks), GSM (900/1800/1900MHz), 3G compatible. Of course, as its name suggests, it is waterproof!
    - PANASONIC 823P Tropical : A 3'' TFT Fullwidescreen in QVGA resolution (427x240), a 2Megapixels camera, GPS, a 1Seg tuner, Bluetooth, a microSDHC slot (up to 8GB). It is W-CDMA (Japanese Networks), 3G compatible.
    - SHARP 825SH Pantone slide: a 2.8''ASV Widescreen in QVGA resolution (400x240), a 2Megapixels camera, GPS, a 1Seg tuner, a microSDHC slot (up to 4GB). It is W-CDMA (Japanese Networks), 3G compatible.
    - NEC 821N: A 3'' TFT Widescreen in QVGA resolution (427x240), a 2Megapixels camera, a 1Seg tuner, a microSD slot (up to 2GB). It is W-CDMA (Japanese Networks), 3G compatible.
    - PANASONIC 834P MIRROR II: 3'' TFT FullWideScreen in QVGA resolution (427x240), a 2Megapixels camera, a 1Seg tuner, a microSDHC slot (up to 8GB). It is W-CDMA (Japanese Networks), 3G compatible.
    - TOSHIBA 824T: 2.8''TFT WideScreen in QVGA resolution (400x240), a 2Megapixels camera, GPS, a 1Seg tuner, Bluetooth, a microSD slot (up to 2GB). It is W-CDMA (Japanese Networks), 3G compatible.
    - NEC 820N (Phone for Business Man): 3'' TFT WideScreen in QVGA resolution (427x240), a 2Megapixels camera, a 1Seg tuner, a microSD slot (up to 2GB). It is W-CDMA (Japanese Networks), 3G compatible.
    - TOSHIBA 823T (Phone for Business Man): 2.8'' TFT WideScreen in QVGA resolution (400x240), a 2Mégapixels camera, GPS, a 1Seg tuner, Bluetooth, a microSD slot (Up 2GB). It is W-CDMA (Japanese Networks), 3G compatible.
    - PANASONIC 921P: Equipped with a 3.1'' TFT VIERA FullWidescreen in VGA resolution (851x400), a 5Megapixels camera with AF, a GPS, a 1Seg tuner, the Bluetooth and a microSDHC slot (Up to 8GB). It is W-CDMA (Japanese networks), GSM (900/1800/1900MHz), 3G compatible.
    - NEC 821 GLAMOROUS: Equipped with a 3'' TFT Widescreen in QVGA resolution (427x240), a 2Megapixels camera with AF, a 1Seg tuner, and a microSD slot (up to 2GB). It is W-CDMA (Japanese Networks), 3G compatible. The particularity of this one is it displays on the cover small back lighted drawings (For example, small hearts)...
    Mời anh em thưởng thức và tks em 1 cái ^^
  2. Japan Mobile !
    Japan Mobile ! Thành viên
    Ôi chúa ơi, nguy to rồi
  3. Veronica
    Veronica Ex-Mod
    ===> Kiệt tác hic hic Lại còn tím quý phái nữa....sao giờ 905,906,giờ là 923sh,ao ước...
    ==> Máy này dễ thương :x
  4. chiphone
    chiphone Thành viên
  5. Elvis Le
    Elvis Le Thành viên
    Và đây là toàn cảnh các phone ra mùa hè năm nay. Khủng quá Y_Y. Quả thực là bọn Softbank rất chịu chơi ... ra bộ sưu tập theo mùa, mà con nào cũng sặc sỡ màu mè.
    8-}8-}8-}8-}8-}8-}8-}8-}8-}8-}8-}8-}8-}8-}8-}8-}8-}8-}
  6. HuangCai
    HuangCai Thành viên
    trời ơi, chịu không nổi, chúng nó treo 1 dàn như thế là sao , hic hic
    hàng mới nhiều quá, tha hồ cho anh em lựa chọn
  7. X_Men
    X_Men Thành viên
    Chọn về và wait mỏi mòn! :D 920 mở được hy vọng sẽ là bước đột phá vào cách bảo mật của SoftBank để máy nào cũng unlock dễ như ăn cháo! :))
  8. Japan Mobile !
    ra 905i chưa được cầm đã ra 906i, 906i chưa được nhìn thấy đã ra 923. Ác quá
  9. devil_xxx
    devil_xxx Thành viên
    Úi trời ơi, cí j dzậy??? Chắc là đồ chơi thui mà, hôm nào a e đặt hàng cho Nhựa Chợ Lớn làm vài chục kiểu đem về mà treo rùi gắn thêm chữ Mobifone ở dưới nữa cho bọn Softbank sợ chơi >:)
  10. Japan Mobile !
    hình mấy hình trên em thấy đau lòng quá, VN mình chưa làm nổi cái bóng led, còn họ thì toàn công nghệ cao cấp
