Yêu cầu phiên bản Android từ: 2.1 Ảnh chụp màn hình: A genuine spy camera has arrived! My Pre PlayStore Account is terminated by google. please pre version uninstall and install this version. ★ Introduction A genuine spy camera has arrived! This is Super Camera Plus that had overcome the mistakes and weaknesses of the existing spy camera! People who were embarrassed to take pictures of themselves in public! People who want to secretly keep pictures of your lover! All those moments that you have to take pictures without anyone knowing, Super Camera Plus will be there for you! ※ This application is not intended for negative use. The developer is not responsible for any negative use. ※ Please use this application positively. ♡ ★ Features 1. The shutter doesn’t make any sound. 2. You have the option to set the toast. 3. You have the option to view the preview. 4. Auto-shot takes picture continuously and automatically. ★ How to Use 1. Run the application after downloading it. (You can hold down the Search button to Run.) 2. Press the button to take a picture. (The toast will notify you the location of the saved file.) ★ Configuration 1. Press the Configuration button. 2. You can control the resolution setting and the toast setting and view the preview. Tip. You can take a picture without anyone knowing if you turn off the toast notification setting and view the preview. ※ If the program turns off or doesn’t work while taking a picture, select the resolution in the configuration and try again. There are some differences among the features of the hardware. ※ 2.1 version below is available only landscapemode. Xem thêm trên Play Store: Mã: [url]https://play.google.com/store/apps/details?id=com.utilno1.supercamerapro [/url] Tải về: Mã: [url]http://appstore.vn/android/home/app/9680 [/url]
