Swiss Army Knife 1.1.0 - đèn pin, đồng hồ, thước kẻ ...
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 17 Tháng chín 2011.
  1. Khỉ Con interista
    Đây là ứng dụng tổng hợp, bao gồm: đèn pin, đồng hồ bấm giờ, thước kẻ, la bàn, máy tính ...
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    This app contains a set of tiny tools: a flashlight, a ruler, a timer, a stop watch, a compass and a bubble level.
    Each tool does what it is supposed to do. There's no space for special effects like 3d compass, talking level, psychedelic flashlight etc: the goal is to have a lightweight, fast and easy to use set of tools, one "tap" away from your home screen.
    Suggestions, like new features to implement, new tools etc. are welcome. If you want to contribute a translation, please send me an email ;)
    If you find a bug, please send us an email using the proprer main menu function.
    If you only left a comment on the Android Market, it's difficult for us to solve the problem, because usually we need some information (such as smartphone type and version, a way to replicate the problem, etc.)
    Note:
    - Depending on the hardware capabilities of your smartphone, some tools may not be present
    - The permission to use the camera is required in order to turn on the camera flash LED. Some smartphones (for instance the Google Nexus S) don't light the flash LED if the camera is not running. If you check the most popular flashlight apps, you'll find out that they all require this permission. Swiss Army Knife doesn't shot any photos, doesn't save multimedia info onto the flash card and doesn't send anything on the internet: it doesn't require the network permission at all.
    Xem thêm:
    https://market.android.com/details?id=com.digital_and_dreams.android.swiss_army_knife&feature=search_result
    Tải về:
    http://appstore.vn/a/index.php/home/app/2354
