SymbianGuru PhotoFun ( chụp ảnh vui nhộn :D )
Thảo luận trong 'ỨNG DỤNG TỔNG HỢP KHÁC' bắt đầu bởi verylove, 18 Tháng mười một 2010.
  1. SymbianGuru PhotoFun v1.02 S60v3 v5 S^3 SymbianOS9.x Unsigned Cr@cked
    PhotoFun Software allows making funny photos merging the predefined templates with phone camera. Some templates are present in the application, more templates can be downloaded from our website or made from your own photos.
    Great idea for the party game and for joking your friends with MMS.
    [​IMG]This image has been resized. Click this bar to view the full image. The original image is sized 640x360.
    Description:
    With PhotoFun application you can have funny photos for sending to your friends or just for fun. It is very easy to use PhotoFun: you just make photos with your mobile camera with templates. Funny photos are ready for sending with MMS or sharing via Bluetooth.
    With PhotoFun you can:
    • Make most beautiful sightseeing photos without leaving your room
    • Try yourself in a new image: with another haircut or dress
    • Show off with your new limousine or standing in front of your gorgeous villa
    • Make sexy, glamorous, shining photos with celebrities and send them to your friends for fun
    • Make party or wedding photos using templates, just imagine all the fun you can get!
    PhotoFun Settings:
    You do not need to set anything to start PhotoFun usage, just open your mobile camera clip and launch the app. You can adjust settings according to your needs any time.
    You can set the size of the photo and image resolution.
    Depending on the daytime you can tune the night and flash modes.
    If you want to see the photo immediately after capturing you can turn this option on and you will be able to see all your photos after being captured.
    You can set custom names to your photos and choose the memory that will be used to save your images.
    To download the pack of free templates, which were sent by users, you can here
    Note!
    You need to install this pack on your memory card or on phone memory. It depends on where you have installed the PhotoFun software.
    How to create your own template:
    To create your own template with the help of MS Paint, you should do the following:
    1. Launch the software and insert the image. Resize the photo, so the size of the photo is 320*240 pixels
    2. Highlight the region which should be transparent with the colour different from the present ones
    3. Fill the upper left pixel with the same colour
    4. Save your pictures in the *.png format. The file extension symbols should be changed from the capital to the small ones
    5. After your picture is saved you can transfer it to your mobile phone with the help of Bluetooth or Datacable to your mobile phone to the PhotoFun - Templates folder on Phone memory or Data - PhotoFun - Templates folder.
    6. In order to see your own template you should open the program and change the current template to the new one. Press Options -> Change Template and select your own image from the list of all possible.
    To create your template with the help of Adobe PhotoShop, you should do the following:
    1. Launch PhotoShop application
    2. Create new file 320*240 points with resolution 72 dpi
    3. Copy the image and resize it to the necessary image size
    4. Create new transparent Layer above the image
    5. Select Pencil tool and choose the colour different from the present ones
    6. Fill the region which should be transparent on your template with this contrast colour
    7. Fill with the same colour also upper left pixel of this image
    8. Save the image as png file
    9. See that the extension of the file is written with small letters
    Change-log
    • Now PhotoFun is fully compatible with Symbian Series 60.5 and Symbian^3: Nokia 5235 Music Edition, Nokia 5230 Nuron, Nokia C6-00, Nokia 5228, Nokia 5250, Nokia C5-03, Nokia C7-00, Nokia C6-01, Nokia E7-00, Nokia N8-00
  2. chimto999
    chimto999 Thành viên
    Cái này hay quá, chụp hình vui nhộn như các máy đời trước. Đã signed và cài, nó báo trial 3 ngày. Hị hị, có ai có key không nhỉ?=P~
    HỊ hị, mò mẫm, đánh thử vào phần registed 0000 thì nó báo thành công, mừng quá. Anh em đăng ký mà dùng nha=D>
    vanvu thích bài này.
  3. verylove
    verylove Staff Member
    hix , đã bẻ nó rồi . nhập số bất kì mà bạn
  4. koconguoiyeu
    koconguoiyeu Thành viên
    Pmềm này hay ghê :D
  5. applelife
    applelife Thành viên
    chưa hiểu lắm, nhìn thì cũng bt :D
