SymbianOn Security v5.0 S60v3 v5 SymbianOS9.x Unsigned-FoXPDA "Security" application is a value-added service on Nokia S60 platform. It have lots of functions: 1. Lock and Protect Application, such as Messages, Pictures, Contacts, Video or any other. 2. Phone Guardian. 3. Turn off and Open mobile phone in time. 4. Record phone call conversations without beep sound and time limitation. 5. Record voice without limitation. 6. Keyboard autolock Some features: For security reason, the application can only be auto-started at the machine boot-up. Once the application is installed, a user cannot find it anywhere in the "My Own" or "Installed" folders. The main reason for this is that it prevents the phone-picker from un-installing the application and/or finding the existence of the application on the phone if the phone is lost. In order to enter the application, a user has to "dial" a password (which is defined by the application) plus a "#" character in the active idle screen. The default password is "123456", which means, if a user wants to enter the application, the user needs to input the following character sequence in the active idle screen (like the way a user gets the IMEI number): 123456# Once the user has entered the application, the user has the freedom to change the password to any other ones (which consists of numeric numbers from "0" to "9"). Then length of the password should be no less than 6, and the maximum length is 10. NOTE: Since it only accepts keys when "Phone" application is in the foreground (idle screen), it is strongly recommended pressing any of the keys to bring up the dialog for inputting phone number first, then key in the password. The following key input sequence is accepted: 1123456# or 1223123456# if the password is "123456", Only the last few digits are compared with the saved password in the application. Main Functions : Lock and protect Applications A user may select any of the applications to be locked. As such, once the application is selected to be locked, the application cannot be launched unless it is set to be unlocked. For example, if an application called “Messaing” is selected to be locked, the application cannot be launched in any ways. A locked application is shown in the window with a “Lock” icon. Only after a user enters “Security” again to make it inactive by clicking the pressing “OK” key, the application becomes accessible again. Phone Guardian It can protect a mobile user from losing his/her phone just in case the phone is lost. For example, if a user has lost his /her phone and someone has picked up the phone. If another SIM card has plugged into in the phone, then a customized message will be automatically sent out to the pre-defined mobile numbers at the boot-up of the phone. In this case, the user can get to know the person's mobile number. Recorde phone call If there is an established call, simply press “#” key; release the key “#”; then press “9” key, it will start the recording over the telephony line. Another repeat of the above key combination (“#” + “9”) will stop the recording process. If a user wants to record it again, then the user just needs to press the key combination again will start telephony recording again and so on. All of the data recorded during a call session will be saved into one single file. A user may check the file in the “Audios” window of “Security” or from the S60 “Media gallery”. For some of the phones, which have the camera key, a user may also use the camera key to do the telephony recording. One press will trigger the call recording, and another camera key press will stop the recording. Press the key again, it will trigger recording again. The recorded file name will start with the telephone number, and its extension name is “amr”. AutoLock time interval Define the time interval for activating the key lock . Turn off and Open mobile phone in time. The mobile phone will be turned on or turned off automatically at the time defined in application. Auto start enable, Hide itself perfectly Once the application is installed, a user cannot find it anywhere in the "My Own" or "Installed" folders,you just can input the password to activate the application. By default, this application is auto-started, and this is the ONLY way to get the app started. If a user turned this option to off, then this application will never have a chance to start it again unless the user re-install the application. Note : After Installation Restart Your Phone
_ Phần mềm này cũng khá hay, trước kia dùng BB xài SafeBox giờ sang thằng này hơi lọng gọng nhưng có vẫn yên tâm hơn! Thanks bro nhe!
tét rồi xin báo cáo: nokia N78 cài vô tư, xài vô tư nhưng vài ngày sau thi vào chương trình vô tư, nhưng các tác dụng đã cài đặt vào thì mất hết tác dụng dù bấm hide chứ ko exit chương trình.
Các bro cho mình hỏi, mình dùng N73 sau khi cài xong thì không thấy biểu tượng của chương trình. Không biết máy của mình có vấn đề gì không, nhờ các bro hướng dẫn giúp. Cảm ơn các bro.
Note : After Installation Restart Your Phone Ghi chú : Sau khi cài đặt phải KHỞI ĐỘNG LẠI ĐIỆN THOẠI của bạn ! Các bạn có quên bước này không đấy !?!
Chuẩn ko cần chỉ,sau khi restart thì tại manf hình home của DT bạn ấn 123456# thì sẽ vào Phần mềm. VÌ PM này ko hề có shortcut như thông thường, sau đó mới đổi Pass được,hi vọng lần sau các bạn có chút hướng dẫn với những PM dặc biệt ntn
