Tap2Switch v1.0 S60v5 SymbianOS9.x Unsigned Small application - touch button to switch between running applicatons for Ur s60v5 smartphone Adjustable position on screen, size, transparency level. How to use the button: - tap to cyclic switching between running applications - hold to close active application - double tap to show\hide list of running apps Bugs: -sometimes U can see two buttons instead of one (after changing its position). Kill tap2swich app using Ur task manager and restart it. -sometimes autostart isn`t working Compatibility: all s60v5 Test: SE U8i Author:Kola
