Tasks+ Todo Manager Pro 0.9.87 - lập danh sách việc cần làm
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 12 Tháng chín 2011.
  1. Khỉ Con interista
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    Tasks+ Todo Manager with Google Tasks sync
    Tasks+ is an easy to use, intuitive task and to-do list manager that fully synchronizes with Google Tasks.
    Featuring highly customizable widgets and a simple, clean user interface, Tasks+ is designed to be an effective solution to organizing your tasks.
    Features include:
    • Simple, intuitive interface optimized for HDPI screens
    • Customizable appearance and behaviour
    • Supports FULL Google Tasks synchronization of lists, tasks & subtasks. (Free version limited to one sync/day after initial sync. Pro version has unlimited sync, auto-sync and selective list sync functionality.)
    • Set task priority
    • Sort tasks by title, due date, creation date, priority
    • Reminders:
    • Quick reminders from current time
    • Repeat reminders (e.g. set times on certain days)
    • Customize notifications with ringtone/alarm sounds
    • Snooze function (adjustable in Pro)
    • Move tasks between lists and create lists from tasks
    • “Share Via” using other apps to e.g. email or message a task
    • Search within task names and notes
    • Speech to task using Google Voice (requires Voice Search to be installed)
    • Built-in help and tutorial
    Highly customizable widgets:
    • Font size and colour
    • Button appearance
    • Background colour, transparency and gradient fills
    • Border style
    • Bullets and numbering
    • Display or hide subtasks
    • Priority indicators
    • Due date highlighting and display
    • Fullscreen (4x4), 4x2 and 2x2 sizes (more sizes coming soon)
    • Wide mode / 2 column mode (for 4x2) widget
    • Custom WidgetStyles (group of settings that define the widgets appearance)
    • Several included
    • Save and re-use between widgets (Pro only)
    ** AD SUPPORTED AFTER 2 WEEKS **
    Please purchase the unlocker key from the market to unlock Pro features and remove adverts.
    PRO Features:
    • Ad free (Lite version is ad-supported after 2 weeks)
    • Google Tasks sync:
    • Unlimited syncs
    • Auto-sync – set a background sync interval
    • Selective sync – select which lists should be synced
    • Checkboxes and task click functionality for full screen widget
    • Full color picker for backgrounds, widgets and notifications
    • Hidden lists – hide less frequently used lists for easier management
    • Save and reuse custom WidgetStyles
    • Adjustable snooze time for notifications
    • Set wallpaper background
    • Choose list colors
    Xem thêm:
    https://market.android.com/details?id=com.iss.tasksplus&feature=more_from_developer
    Tải về:
    http://appstore.vn/a/index.php/home/app/2096
