Thảo luận Tắt Active stanby không dùng Patch trong RomPatcher
Thảo luận trong 'S60 3rd: KIẾN THỨC & KINH NGHIỆM' bắt đầu bởi Be Yeu, 21 Tháng mười 2009.
  1. Be Yeu Super Moderator
    Turn Off Active standBy no Patches in rompatcher
    This solution does not set active standby to default after phone restart like ROMPatcher patch does!!
    1 - turn off active standby
    2 - copy from z:\resource AIPluginDefinition.rsc to c:\resoucre
    3 - edit c:\resource\AIPluginDefinition.rsc via xplore to disable or enable plugins
    3.1 - see below and check plugin uid you like to show or not show
    3.2 - open AIPluginDefinition.rsc via xplore (select file and push 8)
    3.3 - search uid via hex-search
    3.4 - change first occurring uid to some other uid (for example change xxxxxx10 to xxxxxx11 - easy to remember later to change it back - change then xxxxxx11 to xxxxxx10)
    3.5 - save file
    4 - activate active standby
    Here the list of available plugins:
    (uid-********-****-****-****************)
    05871f10-0200-01-00-00000000 - Shortcut
    527d0020-0200-01-00-527d0020 - search
    07871f10-0200-01-00-00000000 - organizer (e90 02000150 01100000)
    09871f10-0200-01-00-09871f10 - todo
    18871f10-0200-01-00-18871f10 - mplayer
    0d871f10-0200-01-64-0d871f10 - aioperatorplugin (e90 sim service)
    d61c2810-0200-01-00-d61c2810 - wlan
    7fa70020-0200-01-00-00000000 - share
    898a2010-0200-01-00-898a2010 - radio
    c7090020-0200-01-00-c7090020 - printintent ****?
  2. uppppppppppppppppppp
