SymbianGuru AutoProfiles v3.30 S60v3/v5 SymbianOS9.x Signed Full Auto Profiles performs automatic profiles activation on your Series 60.5/60.5 Symbian Smartphone. Profile change is made using your personal schedule with rules. The schedule is totally adjustable, with options for activation and deactivation of mobile native and user defined profiles. In schedule you can choose among the variety of recurring conditions (once, daily, weekly, on weekdays, on weekends, monthly, yearly). AutoProfiles includes also Bluetooth scheduler. You can have the Bluetooth status changed automatically according to your schedule: you can turn Bluetooth off, turn it on and choose its visibility status. You can change Bluetooth together with a profile, but you can also change only Bluetooth status without profile change. Auto Profiles reads your mobile calendar entries and activates the chosen profile (for example Silent or Meeting) during the meeting time automatically. This option is preset already, so by default the Profile Meeting will be set during your meetings when you install and activate the AutoProfiles. You can choose to change profile only on selected meetings. To do this, you will have only to place tag in your mobile meeting description and tune the software. For your convenience Auto Profiles have Today tab, where all schedules planned for the current day are visible. Key Features: * Automatic profile timer based on schedule * Bluetooth scheduler includes hidden and visible for all statuses * Change to selected profile during a meeting in the mobile calendar * You can select meetings on which AutoProfiles should be active * Every schedule entry can be activated and deactivated at any time * Scheduling of mobile native and of user defined profiles * Profile deactivation time can be chosen * Overlapping scheduling not a problem due to different priorities for schedule conditions * Today tab shows all profile changes scheduled for the current day * The software is fully compatible with mobile phones Series 60.5 * New languages added * Workdays are user defined Google tạm dịch : Chương trình thực hiện tự động kích hoạt cấu hình tự động trên Symbian Series 3rd và 5th của bạn . Đổi cấu hình được thực hiện bằng cách sử dụng lịch trình cá nhân của bạn với các quy tắc. lịch trình là hoàn toàn có thể điều chỉnh, với các tùy chọn để kích hoạt và Chấm dứt hoạt của bản di động và người sử dụng xác định cấu hình. Trong lịch trình bạn có thể chọn trong số các loạt các điều kiện theo định kỳ (một lần, hàng ngày, hàng tuần, vào các ngày trong tuần, những ngày cuối tuần, hàng tháng, hàng năm). AutoProfiles bao gồm cũng lên lịch và Bluetooth. Bạn có thể có tư cách Bluetooth thay đổi tự động theo lịch trình của bạn: bạn có thể bật tắt Bluetooth, chuyển nó vào và chọn khả năng hiển thị trạng thái của nó. Bạn có thể thay đổi Bluetooth cùng với một profile, nhưng bạn cũng có thể thay đổi chỉ có tình trạng Bluetooth mà không cần thay đổi hồ sơ. Auto Profiles lần đọc các mục lịch di động của bạn và kích hoạt cấu hình đã chọn (ví dụ: Silent hoặc Hội nghị) trong thời gian cuộc họp tự động. Tùy chọn này đã được định sẵn, do đó, theo mặc định các hồ sơ Hội nghị sẽ được thiết lập trong các cuộc họp của bạn khi bạn cài đặt và kích hoạt các AutoProfiles. Bạn có thể chọn để thay đổi hồ sơ chỉ về các cuộc họp được chọn. Để làm điều này, bạn sẽ phải chỉ để đặt từ khóa trong mô tả cuộc họp di động của bạn và điều chỉnh phần mềm. Đối với Hồ sơ tự động thuận tiện cho bạn có tab Hôm nay, nơi mà tất cả lịch trình kế hoạch cho ngày hiện tại có thể nhìn thấy. Tính năng chính: * Tự động hẹn giờ thông tin dựa trên lịch * Bluetooth lên lịch bao gồm ẩn và rõ ràng cho tất cả các trạng thái * Thay đổi để lựa chọn hồ sơ trong một cuộc họp trong lịch điện thoại di động * Bạn có thể chọn các cuộc họp mà AutoProfiles nên được hoạt động * Tất cả các mục nhập lịch trình có thể được kích hoạt và vô hiệu hoá bất cứ lúc nào * Lập kế hoạch của bản di động và của người sử dụng xác định các cấu Chấm dứt hoạt * Thông tin được thời gian có thể được lựa chọn * Chồng lấn lên lịch không phải là một vấn đề do các ưu tiên khác nhau cho các điều kiện lịch * Hôm nay đã có tab hiển thị tất cả thay đổi profile theo lịch trình cho ngày hiện tại * Phần mềm này là hoàn toàn tương thích với điện thoại di động Series 60,5 * Ngôn ngữ mới được thêm vào * Ngày công lao động được người dùng định nghĩa
