Theme 1nfect3d n3w st1le
Thảo luận trong 'Multimedia - Themes' bắt đầu bởi Khỉ Con, 8 Tháng mười 2011.
  1. Khỉ Con interista
    Yêu cầu:
    iPhone / iPod Touch 4. (Retina Display)
    iFile. (They need to change the climate of your city) Download it from the repo
    Program to go to their devices via SSH (for PC can be ... ¨ iFunbox, WinSCP, etc. iPhone Explorer .... If you have MAC could be the Cyber ​​Dock ¨) ...
    Hướng dẫn cài đặt:
    To install the Theme · n3w st1le 1nf3ct3d · The decompressed and appear several folders via SSH will stick to the path ... Var / Stash / Themes.
    After 1nfect3d n3w to Install · cube ¨ st1le will do the same uncompressed and go the same route ... Var / Stash / Themes.
    Now decompress the ¨ 1nfect3d SBSettings st1le n3w ¨ and put you on this route ... Var / Mobile / Library / SBSettings / Theme.
    The issues mentioned first, those assets in Winterboard ... For the theme will have to enter SBSettings SBSettings / More / SBSettings Theme. And selecconan.
    The ¨ Keyboard Color · Well by default in the theme of SpringBoard ... To activate it ... have to go to Settings / Color Keyboard / Select Themes.
    If you do not have Keyboard • lo ° Color downloaded from the repo ... repovip.com
    Tải về:
    [URL="http://www.multiupload.com/6QEE30JN8U"]http://www.multiupload.com/6QEE30JN8U[/URL]
    minhque and 2BanTayTrang like this.
