ThinkChange FingerPrint v3.10 ( bảo mật bằng dấu vân tay ;)) )
Thảo luận trong 'ỨNG DỤNG HỆ THỐNG' bắt đầu bởi verylove, 29 Tháng mười một 2010.
  1. ThinkChange FingerPrint v3.10 S60v5 S^3 SymbianOS9.x Full UNSigned Retail by POPDA
    [​IMG][​IMG]
    Description
    When the FingerPrint screen pops up, you need to touch your finger to the screen to be "scanned" for your identity, there will be vibration and beep sounds during the scan. The phone will be unlocked not depend on whose finger it is, but on how many beeps or vibrations since your finger touch the screen ;-) Play the trick with your friend to show off your phone and make some fun with this top quality and most popular app TODAY!
    How to use
    Unlock Condition (times) - Beep/Vibrate times to unlock
    - if you set it to 0, once your finger is removed, the phone will be unlocked!
    - if you set it to 3, remove your finger after hearing 3 beeps or the phone vibrate for 3 times, the phone will be unlocked! Otherwise, an "Access Denied" red box will be displayed ;-)
    Phone Supported
    Nokia: 5228, 5230, 5233, 5235, 5250, 5530, 5800, N97, N97 mini, X6, C5, C6, C7, N8
    Samsung: GT i8910 Omnia
    Sony-Ericsson: U1 Satio, U5 Vivaz, U8 Kanna
    keke05 and longtiger like this.
  2. Khỉ Con
    Cập nhật ThinkChange FingerPrint v3.10 S60v5 S^3 SymbianOS9.x Full UNSigned Retail by POPDA ở bài đầu
  3. longtiger
    longtiger Thành viên
    Cho mình hỏi, máy mình N8, đã Hack bằng Phoenix và rompatch, sau cài vào vẫn bị báo lỗi chứng chỉ vậy bạn!
  4. Khỉ Con
    Bạn vào rompatcher, apply patch installserver xem sao :-?
