Thinking Space Pro 2.32 - thiết lập sơ đồ tư duy trên Android
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 10 Tháng chín 2011.
  1. Khỉ Con interista
    Yêu cầu: 1.6+
    Thinking Space Pro giúp bạn tạo sơ đồ tư duy (giống Mindmap, tonybuzan... trên PC) ngay trên chiếc Android của mình.
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    Create visual thought maps that help organize and plan your activities and ideas
    Mind Mapping for Android! Portable Mind Mapping has never been so fun!
    Create visual mind maps that help organize and plan your activities and ideas.
    ✔ Awesome mind mapping tools (links, notes, colors, icons)
    ✔ Great for study, meetings, tasks, planning, go wild!
    In addition to the features provided by the ad-supported free version, the Pro version also includes the following:
    ✔ Remove Adverts
    ✔ File Hyperlinks (for Images, PDF, audio)
    ✔ Folders/Tags
    ✔ Styles mode
    ✔ Full Screen Mode
    ★File Hyperlinks allow you to link files from your Android device, such as PDF and Audio recordings to nodes.
    ★Tags/Folders allow you to sort Mindmaps on your title screen into 'Folders' through the use of tags and categorys. This allows you to organize your mindmaps, so that you can find the ones you want faster.
    ★Styles allow you to save the appearance of nodes to a library, so that you can later apply the same look (graphic, font size, color, etc) to any other node with a touch of a button.
    ★Full screen mode allows you to hide the Android notification bar, giving you a little bit extra screen space.
    ★Adverts are completely removed from the Pro version.
    Files produced by Thinking Space are compatible with the following 3rd party desktop Mind Mapping applications: Freemind, Xmind, MindManager, and MindMeister API for premium MindMeister users.
    Xem thêm:
    https://market.android.com/details?id=net.thinkingspace.license&feature=search_result
    Tải về:
    http://appstore.vn/a/index.php/home/app/2185
