Tốc độ CPU của một số model NOKIA
Thảo luận trong 'S60 3rd: KIẾN THỨC & KINH NGHIỆM' bắt đầu bởi kiencuongvn, 20 Tháng ba 2007.
  1. kiencuongvn Thành viên
    Nokia mobile phones processors
    model: type: processor type: architecture: frequency: additional:
    Nokia 3230 RM-51 32-bit RISC CPU ARM-9 123 MHz
    Nokia 3600 NHM-10 32-bit RISC CPU ARM-9 104 MHz
    Nokia 3620 NHM-10(X); 32-bit RISC CPU ARM-9 104 MHz
    Nokia 3650 NHL-8 32-bit RISC CPU ARM-9 104 MHz
    Nokia 3660 NHL-8X 32-bit RISC CPU ARM-9 104 MHz
    Nokia 6260 RM-25 32-bit RISC CPU ARM-9 123 MHz
    Nokia 6600 NHL-10 32-bit RISC CPU ARM-9 104 MHz
    Nokia 6620 NHL-12 32-bit RISC CPU ARM-9 150 MHz
    Nokia 6630 RM-1 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia 6670 RH-67 32-bit RISC CPU ARM-9 123 MHz
    Nokia 6670B RH-68 32-bit RISC CPU ARM-9 123 MHz
    Nokia 6680 RM-36 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia 6681 RM-57 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia 6682 RM-58 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia 7610 RM-51 32-bit RISC CPU ARM-9 123 MHz
    Nokia 7610B RH-52 32-bit RISC CPU ARM-9 123 MHz
    Nokia 7650 NHL-2(NA); 32-bit RISC CPU ARM-9 104 MHz
    Nokia 770 SU-18 TI OMAP 1710 ARM-926 220 MHz
    Nokia 7710 RM-12 32-bit RISC CPU ARM-9 150 MHz
    Nokia 9210 RAE-3(N); 32-bit RISC CPU ARM-9 52 MHz
    Nokia 9210c RAE-3(N); 32-bit RISC CPU ARM-9 52 MHz
    Nokia 9210i RAE-5(N); 32-bit RISC CPU ARM-9 52 MHz
    Nokia 9290 RAB-3(N); 32-bit RISC CPU ARM-9 52 MHz
    Nokia 9300 RAE-6(N); TI OMAP 1510 ARM-925 150 MHz
    Nokia 9300B RA-4 TI OMAP 1510 ARM-925 150 MHz
    Nokia 9300i RA-8 TI OMAP 1510 ARM-925 150 MHz
    Nokia 9500 RA-2 TI OMAP 1510 ARM-925 150 MHz
    Nokia 9500B RA-3 TI OMAP 1510 ARM-925 150 MHz
    Nokia E50-1 RM-170 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia E50-2 RM-171 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia E60 RM-49 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia E61 RM-89 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia E62-1 RM-88 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia E62-1 RM-88A TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia E70-1 RM-10 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia E70-2 RM-24 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia N-Gage NEM-4 32-bit RISC CPU ARM-9 104 MHz
    Nokia N-Gage QD RH-29 32-bit RISC CPU ARM-9 104 MHz
    Nokia N-Gage QDA RH-47 32-bit RISC CPU ARM-9 104 MHz
    Nokia N70-1 RM-84 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia N70-5 RM-99 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia N71-1 RM-67 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia N71-5 RM-112 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia N72-5 RM-180 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia N73-1 RM-133 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia N73-? RM-132 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia N80-1 RM-92 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia N80-3 RM-91 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia N90-1 RM-42 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia N91-1 RM-43 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia N91-5 RM-158 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia N92 TI OMAP 1710 ARM-926 220 MHz + RAP.. cellular CPU
    Nokia N93-1 RM-55 TI OMAP 2420 ARM-11 330 MHz + RAP.. cellular CPU
    Nokia N93-5 RM-153 TI OMAP 2420 ARM-11 330 MHz + RAP.. cellular CPU
  2. FVA
    FVA Thành viên
    sao ko có 3250 xpress music nhỉ?
  3. co7610thicho22
    co7610thicho22 Thành viên
    coi để biết thôi chứ có làm được gì đâu đúng kg vậy pác
  4. vietkim
    vietkim <b>Google MẸO</b>
  5. Pháp Sư
    Pháp Sư Thành viên
    Bác có lộn không vậy????? Hình như N73 CPU không đến 220 MHz mà khoảng 206 MHz thôi mà. Bác test lại thử
  6. minhluat
    minhluat Guest
    Vậy còn 3250 tốc độ bao nhiêu? Thấy nó chạy game mà để tiếng thì ì ạch, giựt hoài, chạy ko nổi luôn, game nào chơi cũng phải tắt tiếng hết, chỉ dám mở rung thôi..chán phèo...
  7. tiachopxanh291
    tiachopxanh291 Thành viên
    Ai bảo thế.Tui dùng 3250 nè. Dùng Active File Kiểm tra thông số :
    CPU Speed: ARM 235 Mhz
    Ram 32 mb
    Chạy game ầm ầm có giật gì đâu.Thậm chí có khi vừa chơi game vừa bật nhạc vẫn ok.
    Chắc máy bác minhluat có vấn đề rùi. :)
    Tôi đang đánh skyforce và nghe nhạc nè. ok hết!
  8. mobileman
    mobileman Thành viên
    N95 có 206 MHz thôi, thế mà có bác nói 330
  9. toohot
    toohot Thành viên
    mình cũng thấy ngạc nhiên về tốc độ của N95, chậm khủng khiếp, ko hiểu nhà sản xuất có dụng ý j khi cho N95 tốc độ còn chậm hơn cả 6681, bộ nhớ Ram còn ít hơn cả N-gage, chỉ đc mỗi cái GPS với âm thanh hay thôi.
  10. namdung
    namdung Thành viên
    Ai bảo các bác là N95 tốc độ 206 Mhz, nếu với tốc độ đó có mà các bác vào nửa tiếng may ra mới chạy được chương trình. N95 có tốc độ 330 Mhz, dùng chip ARM11, và chip đồ họa 3D tăng cường, các bác tranh cãi làm gì, các bác vào đây là biết tất cả các tốc độ của dòng máy Nokia nhé:
    http://forum.nokia.com/devices/matrix_all_1.html
    Các bác cứ vào đấy là biết thôi, trang chính thức của Nokia đó.
