Tools dùng để signed ứng dụng chạy trên điện thoại
Thảo luận trong 'S60 5th: FIRMWARE - SIGN - HACKPHONE' bắt đầu bởi minhtue, 13 Tháng hai 2010.
  1. minhtue Super Moderator
    S60SignSis v2.1 S60v3/v5 SymbianOS9.x Unsigned
    [​IMG][​IMG]
    s60SignSis v2.1 - Tools for mobile phone, add signatures, have support batch operations and functions removal of signature.
    This is SignatureTool is only suitable for smartphones of the certificate, the certificate obtained from other
    sources cannot be used in smartphones. Address for ordering a certificate - "http://cer.s603rd.cn" .
    Software Name: S60_signsis;
    Software Version: V2.1;
    Software Type: Auxiliary packaging tools;
    License: Free Edition, direct of installation;
    Programming: junnikokuki;
    Interface: English, Chinese;
    Test models: Nokia N73 theoretical support s60v3, S60v5 models (other models need testing installation);
    PS: This tool can be signed (PublisherID) 17 certificate of authority;
    Description of functions:
    The signature tool support directly to signing in the phone, batch operations, the software can also remove the
    signature. After installing to the phone, run program and look [Options\Settings]:
    1. To import your certificate.
    2. Output file path (optional).
    In "the Add a task" need add the software that you want to sign: (disk drives C / E option to find, add)
    At the same time you can select the operations: Sign Sis or Remove Sign!
    After signing your program. If in process installing program appear the error "could not be installed".
    Possible solution:
    1. Please check in smartphone: [Menu\Tools\Settings\Applications\App.manager\Softw are installation - select ALL,
    Online certificate check - select OFF;
    2. Use the tool to remove signature inside the program (firstly use the function remove the signature and then
    signing software).
  2. minh hai 123
    minh hai 123 Thành viên
    Mình ko biết đọc tiếng anh!
  3. Be Yeu
    GoOOogggglllleeeeeeeeeeeee dịch giúp bạn nhé !
    s60SignSis v2.1 - Công cụ cho điện thoại di động, thêm chữ ký, có hàng loạt các hoạt động hỗ trợ và loại bỏ các chức năng của chữ ký.
    Đây là SignatureTool chỉ thích hợp cho điện thoại thông minh của các chứng chỉ, chứng chỉ thu được từ khác
    nguồn không thể được sử dụng trong điện thoại thông minh. Địa chỉ cho đặt một chứng chỉ - "http://cer.s603rd.cn".
    Tên phần mềm: S60_signsis;
    Phiên bản phần mềm: V2.1;
    Loại phần mềm: công cụ đóng gói phụ;
    Giấy phép: Free Edition, trực tiếp của tiến trình cài đặt;
    Lập trình: junnikokuki;
    Giao diện: Tiếng Anh, tiếng Trung Quốc;
    Thử nghiệm các mô hình: Nokia N73 hỗ trợ lý thuyết S60v3, S60v5 mô hình (các mô hình thử nghiệm khác cần cài đặt);
    PS: Công cụ này có thể được ký kết (PublisherID) 17 giấy chứng nhận quyền;
    Mô tả các chức năng:
    Các công cụ hỗ trợ trực tiếp để ký chữ ký trong điện thoại, hoạt động theo đợt, phần mềm cũng có thể gỡ bỏ
    chữ ký. Sau khi cài đặt vào điện thoại, chương trình chạy và tìm kiếm [Tùy chọn \ Cài đặt]:
    1. Để nhập khẩu giấy chứng nhận của bạn.
    2. Đường dẫn ra tập tin (tùy chọn).
    Trong "Thêm một nhiệm vụ" cần thêm các phần mềm mà bạn muốn đăng nhập: (ổ đĩa C / E tùy chọn để tìm, thêm)
    Đồng thời bạn có thể chọn các hoạt động: Đăng Sis hoặc Xoá Đăng!
    Sau khi ký kết chương trình của bạn. Nếu trong quá trình cài đặt chương trình xuất hiện các lỗi "không thể được cài đặt".
    Có thể có giải pháp:
    1. Hãy kiểm tra trong điện thoại thông minh: [Menu \ Tools \ Settings \ Applications \ App.manager \ Softw được cài đặt - chọn ALL,
    Giấy chứng nhận kiểm tra trực tuyến - chọn OFF;
    2. Sử dụng công cụ để loại bỏ chữ ký trong chương trình (trước hết là sử dụng chức năng loại bỏ các chữ ký và sau đó
    ký kết phần mềm).
    dungsiga92 and tungoc11 like this.
