Current Version:1.1 requires Android:1.5 and up Size:1.0MB V1.1 update: 1. Add sound effect; 2. Remove ghost piece setting option. A Tetris clone played on a ring-like 3D surface. As far as Tetris goes, most variations look quite similar. You’re usually looking at a “wall” of bricks directly from the front. Torus 3D Pro takes that notion and throws it away; as you might have guessed from the name (or screenshot), this Tetris clone is played on a ring-like 3D surface. Key features: ♥ 3D effect Tetris-like game ♥ Three game modes ♥ Time attack game mode is available ♥ Garbage game mode is available ♥ Gesture control ♥ Scores can be shared to facebook How to Play: You rotate the ring itself with gesture or the keypad, while a Tetris-like piece slowly descends from the top. As soon as you make a solid line, it disappears. Tips: Not all pieces are Tetris-like; some of them wouldn’t really work with a regular Tetris game but are a good fit for Torus’ 3D format. Download Torus 3D 1.1 apk
