Trapster: Phần mềm chia sẻ vị trí có máy bắn tốc độ qua GPS
Thảo luận trong 'ỨNG DỤNG DU LỊCH, BẢN ĐỒ, GPS' bắt đầu bởi manbk401, 11 Tháng năm 2010.
  1. manbk401 Thành viên
    Trapster v3.7.3 J2ME
    Trapster is a free service that allows users to share the location of police speed traps using their mobile phones. The system uses the phone's GPS capabilities and the Internet to instantly alert other users as they approach the reported trap.
    When you see a trap, report it by pressing a button on your phone, or calling a toll free number. Other users' phones will alert them as they approach the trap. Trapster learns the credibility of traps based on how many users agree. It also learns the credibility of each user, over time.
    Even the latest, most expensive radar detectors are useless against modern police enforcement technologies such as instant-on and and laser. Your radar/laser detector will still beep, but in almost all cases, only after it is too late. The only way a radar or laser detector can help you is if it beeps in time for you to slow down before the officer gets a reading on your speed. With instant-on and laser, this only happens if the officer activates early or "misses" the shot, and some of the signal leaks past a car in front of you. Radar detectors are still effective for more traditional (Ka etc.) band radar. It is recommended that you use both Trapster and a radar/laser detector for the best possible coverage. Also radar detectors are illegal in many US states, and are illegal nationwide for commercial vehicles.
    Requirements:
    · MIDP 2.0, CLDC 1.1
    · GPS receiver
    What's New in This Release:
    · Added Nokia specific functionality for vibration and backlight.
    · Added feature to enable backlight continuously while application is active.
    · Fixed bug that occurs when a user leaves a wifi zone. Connection is re-established
    · Removed "Switch Application" put to background menu item. Redundant with OS implementation.
    · Added touch functionality for S60 5th Ed.
    · Various minor bug fixes and performance enhancements.​
  2. tichau
    tichau Guest
    Có 1 thread tương tự ở đây
    http://www.gsm.vn/forum/main/showthread.php/193959-Phần-mềm-Trapster!-Báo-bắn-tốc-độ-có-cớm-ở-trước...
    Tuy nhiên cần nói sơ qua về vấn đề này 1 chút.
    Tại VN,khi CSGT tác nghiệp bắn tốc độ thì chủ yếu là các trạm cơ động.Không đứng cố định 1 chỗ như ở nước ngoài nên phần mềm này đối với dân VN là bất khả thi :112:.Tôi đi từ Đồng Nai đến cửa khẩu Tân Thanh ở Lạng Sơn,xe đi trước báo có bắn tốc độ tại điểm A của tỉnh Quảng Bình.Xe tôi đi sau xe trước 2 tiếng ~ 140 km thì lúc đó tổ CSGT đã đến điểm B và bắn ì xèo rồi.Nếu dùng cái app này mà đinh ninh có bắn tốc độ ở điểm A,lúc đó bò ì ạch qua khu vực A.Sau đó đạp tẹt ga đến khu vực B thì bị bắn tốc độ.Thử hỏi liệu cái app này có khả thi tại VN không khi mà CSGT luôn di chuyển khi làm nhiệm vụ ?
  3. Be Yeu
    Thread Closed - Chủ đề đã được đóng lại >>>Lý do :
