Trò chơi cho dòng máy Symbian S60v3 - Phần 1
Thảo luận trong 'S60 3rd: GAMES - TRÒ CHƠI' bắt đầu bởi home, 9 Tháng sáu 2006.
  1. buimanhthang
    buimanhthang Thành viên
    Bác post 2 bản giống nhau toàn tiếng ý,mà anh em đa số chỉ biết tiếng anh.Vậy mong bác tìm hộ anh em bản tiếng anh nhé,game này mình nghiện khi nó xuất hiện trên PC rùi,giờ ra cả cho di động sướng quá
    kohout and dathuynh14 like this.
  2. Liemlovevn
    Liemlovevn Ex-Mod
    Nip Tuck v1.0 240x320 S60v3 J2ME
    66666 and dathuynh14 like this.
  3. Liemlovevn
    Liemlovevn Ex-Mod
    Flying Stick Fighter S60v3 ITA J2ME
    dathuynh14 thích bài này.
  4. Liemlovevn
    Liemlovevn Ex-Mod
    AMA Pulling Power ENG 240x320 S60v3 J2ME BY ALEXE
    [​IMG] [​IMG] [​IMG]
  5. minhque
    Quake II v1.01
    Quake I - a port of the infamous first person shooter (with the same name) for S60 3rd Edition handsets.
    Instalation
    The installation packages on the download page require that you have also a datafile for the game on your memorycard. Both shareware and full version work. Please do not ask me where to find the datafiles. QuakeWorld uses the same datafiles from the same directory as Quake, so there is no extra installation procedure for QW other that it requires the full version of the datafiles.
    1. Find a suitable datafile (either shareware, or the full version form original PC version)
    2. Create "quake1" folder to the root of your memorycard
    3a. If you have the full version, just copy the "ID1" directory to "quake1" directory.
    3b. If you have only a shareware .pak file, create "ID1" folder to "quake1" directory and the copy the shareware pak-file there
    4. If you want to have cdaudio aswell, create "cdaudio" folder to the "quake1" folder. Then put the audio files as .mp3 to the "cdaudio" folder, remember to rename the files from 1.mp3 throught 10.mp3. I don't know what bitrate is the best, but I have used 256kbps and it has impact of 0.1 fps to the performance. If you do not have the required audio files, the background music is just not played.
    5. install the Symbian P.I.P.S. c-runtime library, and the install the suitable version of quake.
    From version 1.04 onwards, the game supports command file parameters via file. The file is either "cmdline.q1" for quake, or "cmdline.qw" for quakeworld. If you want to use command line parameters, just create the required file(s), and place them to "quake1" folder. Use Google to find out what parameters the game support, but ofcourse not all parameters are applicaple. The command line parameters make it possible to play mods, tested with the official mission packs "Scourge of Armageddon" and "Dissolution of Eternity". To play the mission packs, copy "hipnotic" or "rogue" folder from the original mission pack cd to the "quake1" directory and use command line parameters "-hipnotic" or "-rogue"
    Also, please note that in GLquake the brightness slider does not work. You can adjust it via command line parameter by supplying something like this "-gamma 0.7". For GLquake it is also possible to enable full screen antialiasing with -fsaa command line parameter ( will degrade performance)
    If everything is in place, you are ready to rock now.
    Link : http://www.4shared.com/file/46726728/cd6c7984/Quake_II_v101.html?dirPwdVerified=94f9bcf8
  6. minhque
    Quake I v1.04
    Fixed a couple of issues on E90. Softkeys now work again and the not working on cover screen issue has been solved. If you don't have E90, you have no need to update. The latest firmware update fixed the FPU issue on E90, so the choose your version accordingly
    This is a port of the infamous first person shooter for the S60 3rd Edition FP1 based phones. The only thing that is not working is network play.
    This port requires an S60 3rd Edition Feature Pack 1 phone (e.g. N95 or E90) and ARMv6 processor. It will not work on older S60 3rd Edition (non-FP1) phones. You need to install PIPS C Runtime libraries for this software to work.
    [​IMG] [​IMG]
    Currently the keys are mapped as follows when ingame, in console you should be able to type by multitapping:
    LSK = return / jump
    RSK = esc
    Joystick = forward, back, left, right, fire
    * = look around (with joystick)
    # = sidestep
    c = change weapon
    green answer key = center view
    volume up/down = look around/sidestep
    everything else basicly shoots in the game.
    Link : http://www.4shared.com/file/46726879/cc40fa6a/Quake_I_v104.html?dirPwdVerified=94f9bcf8
    tocrungsanchua and dathuynh14 like this.
  7. Liemlovevn
    Liemlovevn Ex-Mod
    ZY-ZY S60v3 J2ME MULTISCREEN
  8. Liemlovevn
    Liemlovevn Ex-Mod
    Rambo Forever 240x320 S60v3 J2ME Rtil-Etty
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    coduocgidau and dathuynh14 like this.
  9. O9xx19xx29
    O9xx19xx29 Thành viên
    Game tiến lên - giao diện tiếng Việt
    Game đánh bài Tiến lên - có giao diện tiếng Việt - trong này có cảc bản tương thích với tất cả các máy chơi được game java nằm trong list sau:
    Trích dẫn:
    Nokia: 2610; 2626; 3120; 3152; 3155; 3155i; 3220; 3230; 3250; 5200; 5300; 6020; 6030; 6060; 6060v; 6070; 6080; 6085; 6085; 6101; 6102; 6102i; 6103; 6111; 6125; 6126; 6131; 6133; 6155; 6165; 6170; 6230; 6230i; 6233; 6234; 6255; 6265; 6265i; 6270; 6275; 6275i; 6280; 6282;6288;6300;6610; 6620; 6630; 6670; 6680; 6680; 6681; 6682; 7210; 7260; 7270; 7360; 7370; 7373; 7390; 7610; 8800; 8800SI; E50; N70; N71; N72; N73; N91;N93; N93i; 6235; 6235i; 6600
    Samsung: D300; D488; D500; D520; D720; D720; D780; D830; D870; D900; E300; E340; E350; E360; E370; E480; E500; E530; E600; E710; E720; E730; E770; E780; E810; E860; E870; E900; i300x; i310; P310; P910 P920; s400i; S501i; S501i; X160; X200; X510; X530;X640; X680;Z146; Z150; Z230; Z300; Z310; Z320i;Z330;Z350; Z370; Z400; Z500; Z520; Z700; E690; E630; D510
    Motorola: A780; C975; C980; E1000; E550; E680; E680i; L7; L7i; Top of Form
    RAZRV3; Bottom of Form
    RAZRV3i; ROKR E1; V180;V188; V220; V3;V300; V360; V3i; V400; V500; V550; V551; V600; V635; V80; V975; V980
    Sony Ericsson: F500i; K300; K310i; K320; K500; K508; K510; Top of Form
    K600; Bottom of Form
    K618; K700; K750; K750i; K750i; K800i; M608; P990i; V600; V800; W300; W550; W600; W700; W700i; W710; W800; W800i; W810; W810c; W850i; Z1010; Z500; Z500; Z500a; Z520; Z525; Z530; Z610; Z710; Z800
    LG: KG110; KG190; KG200;KG800
    Ảnh mẫu
    hxxp://files.myopera.com/echip/files/anh%20mau.JPG
    Download
    hxxp://files.myopera.com/echip/files/tien%20len.rar
    hoặc
    hxxp://mediafire.com/?63ybdzyxjdg
    Các bác đổi xx bằng tt nhé
  10. ng2diep
    ng2diep Thành viên
    @Hehehe, giới thiệu là game cho Symbian Ó 9.1 3rd vậy mà ko thấy Nokia Ê61i đâu cả?
