TTPod - Phần mềm nghe nhạc trên mobile.
Thảo luận trong 'ỨNG DỤNG TIỆN ÍCH + MULTIMEDIA' bắt đầu bởi tichau, 31 Tháng một 2011.
  1. tichau Guest
  2. Khỉ Con
    TTPod v4.00 Beta2 S60v3v5 SymbianOS9.x Unsigned En translated by Kienvp
    Second beta version of powerful music player, now with S^3 devices support!
    Key features:
    ● Full support for S^3 and S60v5 devices
    ● Special interface for control using touch screen
    ● Supported formats: MP3, AAC, WMA and M4A
    ● Built-in equalizer
    ● Sound fade, stereo widening and bass boost effects
    ● Support for skins and visual effects
    ● Ability to download songs, album covers and lyrics
    ● Online access to music charts
    ● Sleep timer
    ● Mini-player in background mode
    and many more features...
    What's new:
    ● Resolved problem with inability to run the program on some models
    ● Optimized ID3 tags editor, improved scanning speed
    ● Fix bug with random mode
    ● Optimized displaying lyrics and tips
    ● Resolved problem with inability to close the app using task manager
    ● Fixed scanning problems
    ● Improved performance and switching speed
    ● Optimized volume difference between MP3, WMA and M4A
    Note : Install TTPOD Patch
    To Run TTPOD
    [URL="http://www.mediafire.com/?7n81675omxgfd5m"]TTpod patch[/URL]
    [URL="http://www.mediafire.com/?11b4tth3bnppkbp"]TTpod 4.0[/URL]
  3. thuyhanlt
    thuyhanlt Guest
    TTPOD 4.0 Beta 3 S60v5 S^3 SymbianOS9.x UnSigned EN By Ayurvedic
    This version applies to the S60 Fifth Edition and Symbian ^ 3 touch-screen phone,
    S60 Fifth Edition
    Nokia 5230/5232/5233/5235/5238/5288/5250/5530/5800/5800i/5800w/5802XM/C5-03/C6/N97/N97i/N97 mini/X6
    Sony Ericsson U1i (Satio) / U5i (Vivaz) / U8i (Vivaz pro)
    Samsung i8910 HD
    Symbian ^ 3
    Nokia C6-01/C7/E7/N8
    New version features
    1, lower operating memory footprint;
    2, optimization songs switch threads to speed up switching speed;
    3, the player interface to support loop sliding;
    4, support Dream Star visualization switching;
    5, increasing lyrics adjustment;
    6, increasing the new landscape mode;
    7, support custom equalizer;
    8, increasing rejection song features.
    A list of changes and new features
    1, the list layout adjustment, return to play and recommended swapped every day;
    2, the list supports semi-transparency;
    3, the list drag the slider to increase rapidly;
    4, the list add the menu, exit the program from the list;
    5, increasing song sorting;
    6, increasing the list of new features.
    Add some personality features
    1, the screen backlight Always switch;
    2, exit prompts switch;
    3, the word graph storage location setting;
    4, Fade switch;
    5, started playing switch;
    6 position switch out memory;
    7, unplug the headset to suspend switch;
    8, the hold button to quickly return switch;
    9, long press the volume side key the song switch.
    Other functions
    1, check for updates to increase functionality;
    2, increasing Tell a Friend feature;
    3, increasing feedback function;
    4, increasing word graph error function;
    5, increased night mode;
    6, the splash screen support for jpg format.
    Fixes
    1, solve the random mode, music player will repeat the question;
    2, solve the "last played" in the song will play two songs loop problems;
    3, the solution after setting the sleep mode, can not be canceled after the cancellation problem will still perform the operation.
    Other Details
    1, the mini-player can support image display;
    2, scanning vibrating alert after the end;
    3, Symbian3 one hundred volume optimization.
  4. thuyhanlt
    thuyhanlt Guest
    TTPod v4.0 Final S60v5 SymbianOS 9.4
    ---------- Post added at 09:31 AM ---------- Previous post was at 08:45 AM ----------
    Skin dành cho ttpod v4
  5. thuyhanlt
    thuyhanlt Guest
    TTPod 4.0 Final English | Exclusive Translation By itZoM™ | New Skins & Effect
    Khỉ Con thích bài này.
  6. phongtg86
    phongtg86 Thành viên
    sao em download ve cai dat su dung dc co 1 lan a may a
  7. Khỉ Con
    là sao bạn, những lần sau bạn bật không được à
    P/S: lần sau nhớ viết tiếng Việt có dấu bạn nhé ^^
  8. thuyhanlt
    thuyhanlt Guest
    TTPod 2011 v.4.0 Final S60v5/S^3 English Fix by Léo Symbian
    [​IMG][​IMG][​IMG]
    Ghi chú / sửa lỗi: ​
    ● Trong các Player vẫn còn có các ký tự Trung Quốc ( dịch 99%).
    ● Các thông tin âm nhạc không được hiển thị.Bạn có thể xem các thông tin bài hát bằng cách nhấp vào "Edit",
    ● Sleep Time làm việc với tất cả các chức năng .
    ● Ứng dụng Unsigned.
    ● Kèm theo Patch
    Tải về
    Khỉ Con and toi_tay like this.
  9. thuyhanlt
    thuyhanlt Guest
    TTPod v4.10 Final S60v5 S^3 SymbianOS9x Unsigned Re-English By ene49
    Đã fix Sleep mode hẹn giờ tắt chương trình :D.​
  10. mabu
    mabu Thành viên
    Bắt buộc phải cài font Pure thì mới hiển thị được English nhá pà con, còn nếu ko thì vẫn toàn là ô vuông thôi! :(
