Ứng dụng mới cập nhật Symbian OS 9 (Phần II)
Thảo luận trong 'ỨNG DỤNG TỔNG HỢP - ỨNG DỤNG KHÁC' bắt đầu bởi ChiêuTrúc, 29 Tháng mười hai 2007.
  1. petrus1105
    petrus1105 Thành viên
    IQ-Mobile.IQ.Talking.Clock.v1.02.S60.J2ME.Crac ked-illusion
    There are a few phones on the market that can tell you the current time by reading it out loud from the system time.
    IQ Talking Clock is a software application that gives your phone the ability to read the current time even if your phone doesn’t have this built in function . IQ Talking Clock takes the phone’s hour and minute and pronounces them out loud letting you know what time it is.
    Tip: Assign a shortcut key on your phone to launch the java application with the press of a single key to hear the current time without you having to browse the entire phone menu!
    This simple and intuitive application gives you the option to adjust the time read from the phone’s current time, thus any error in getting the time can be rectified manually to get the best results.
    lovetodie and letruongdung61 like this.
  2. petrus1105
    FreeTimeSyncS60v3 Beta version time synchronization application 12/06/08
    System time inaccurate still trouble you?
    Changing the battery cause system time reset?
    Why does the powerful S60 3rd system has no specific time synchronization application?
    Network operators time? No effect!
    FreeTimeSync is a S60 3rd's time synchronization application, it is based on the NTP (Network Time Protocol), which provides high-precision time correction (on LAN less than 1 ms, on Internet dozens of milliseconds), and only causes little network flow. FreeTimeSync also supports GPS time sync and SMS time sync.
    FreeTimeSync supports following phones:
    3250、5700、6110N、6120C、6121C、6220C、6290、E50、E51、E60 、E61(i)、E62、E65、E70、E71、N73、N75、N76、N77、N78、N80、N8 1、N82、N91、N93(i)、N95、N96
    FreeTimeSync needs to sign before installion. You can sign it with your dev cert. If you don't know about cert and sign, please visit www.symbiansigned.com and follow the instructions to get FreeTimeSync Open signed.
    Some friends remind me that FreeTimeSync is not the first time sync app on S60 3RD, so I modified the title. Maybe not the first, but I'll make it the best!
    This release is beta version.
    What's new:
    1. Add: Autosync on phone boot
    2. Add: Default AccessPoint setting
    3. Add: Config file, you can now save your server IP
    4. Add: GPS time sync
    GPS time sync function requires your GPS connected. Or it will report sync error.
    5. Add: SMS time sync, and you can customlize your sms number and content
    SMS time sync function will send a sms to the number and start watching, it will set the first sms time as your system time. The default sms number is "10086" and the content is "ye", which is the auto send back number of China Mobile. You may modify it as your will.
    Attention: Because the NTP does not support the WAP gateway, time synchronization function can only based on Internet, which means you can only use it with Internet or WIFI access points.
  3. minhque
    MagicKey V.1.0 s60v3 SymbianOS 9.x Unsigned by Leftup
    (13-06-2008)
    MagicKey 1.0 KeyMap promotion edition support many kinds of plans, may establish willfully the special key (volume and so on
    [​IMG][​IMG]
    bug feeds back and suggested that invites the receipt or the PM function explanation in the procedure tabulation " All procedure " Expression not in this tabulation procedure in key value edition dialog box " Presses a key originally " Expresses on a your keyboard's idle key, uses for to simulate other " The mapping is: " Expressed you need the pressed key will this time press down the dial key to demonstrate 999, waited for that you or will press down in the guidance from a keyboard entry pressed key the key (the OK key) to open the pressed key tabulation, may choose the pressed key which will need. Some commonly used pressed key's tabulation standard shape key left Shift/Rignt Shift 18/19 Left soft key CBA1 164 Right soft key CBA2 165
    New feature:
    This is 1.0 official versions, the next edition preparation increases the quick key to start the closure procedure, increases while convenient suspends, resuming the mapping the function (myself to favor in fixes for power source key) particularly grateful Demson tests many times, enables on FP1 bug to be able to obtain the revision
  4. minhque
    FlyingBird Personal Finance Manager v1.4 S60v3
    (S.i.g.n.e.d Cr++ked-OPDA)
    [​IMG][​IMG][​IMG]
    Flying Money Manager for s60 ver.3 is your personal and business money and budget manager . It’''s proven that using Flying Money Manager is a lot easier than keeping track of all paper receipt..
    Your Intuit Quicken and MS Money handheld companion.
    * Track your personal and business expenses, deposits and transfers, scheduled and other transactions associated with your bank accounts in a easy and intuitive way;
    * Generate customized Reports for integration with Excel for further analysis.
    Main Features
    * Start menu: easy to star and navigate.
    * Account balances at a glance.
    * View account's registry.
    * Budgets: setting up and reports
    * Scheduled Transactions: weekly, monthly, etc .
    * Memorized/Regular Transactions.
    * Export/Import to QIF format for integration with desktop finance software like MS Money, Quicken etc.
    * Finance information security. Encryption. Password-protection.
    * Multiple Account Types e.g. Checking, Saving, Cash etc
    * Multi-currency transactions support with re-calculated accurate amount
    * Splitting transaction categories
    * Extensive and easy to use reporting tool with export to MS Excel
    * Customizable Categories, Expense and Incomes Types, Payment Types and Currencies.
    * Back-up and Restore your financial data.
  5. minhque
    MP3 MyStrands Social Player v. 3.1
    (Update)
    Now with Last.fm scrobbling and completely updated UI!!! from the winner of Mobile Rules 2008 - Best Multimedia Application!!
    The MyStrands Social Player is a MP3 player that lets you discover new music, connect with people, and share your tastes with friends.
    It automatically shows cover art, provides artist and song recommendations from over 6 million songs featuring free previews, and fully integrates with a social network of music enthusiasts.
    The innovative “Who’s Listening” feature lets you discover like-minded people who like listening to the same songs you are playing. You can send messages, discuss up and coming artists, see the listening histories of other users, and keep an ear on what’s hot.
    Now scrobbles also to Last.fm
    MyStrands - What you play counts!
    Test on N95 8G
    hiepkhachhanh thích bài này.
  6. minhque
    LiveStream Mobile v5.0 - expanding mobility
    (Updated)
    [​IMG][​IMG]
    LiveStream is a simple and easy-to-use platform for private and public webcams remote access and control via mobile handset or website.
    Capture video to a file on the fly and access an archive remotely.
    Bundle multiple webcams under single account.
    Free full access for public cameras.
    Setup steps
    1. Download broadcaster
    2. Install & register
    3. Download mobile client
    What's new in this release:
    · Intelligent motion detection mechanism with variety of notification channels:
    · Email
    · SMS
    · IM (GoogleTalk)
    · LiveStream Mobile
    Requirements:
    · Java enabled phone
  7. minhque
    Beeper v6.10 Final Multifunctional utility
    Author : Damian (Ariek44)
    Beeper for S60What does it do? It is really hard to say what the Beeper is because it is the multifunctional application with lot of handy and highly customizable features.
    The application itself is similar to Timebar but it has more useful features and completely configurable window which allow you to select where and which information you want to display. Application of course stays resident in memory and continues to update the display in real time.
    However, what is most interesting about this application is that everything is under control, bar is completely customizable, fonts, colors, items, everything. You can change the Bar size, Bar position and Bar color. It is the same with the text and application allows you to change the Text style, Text color and of course Text position. Furthermore it supports the bunch of items to choose from, you can choose between the Time, Date, Ram, Signal and battery.
    Basically it is capable to show the any system information anywhere on your display and not only on the standby screen, clock, or date, or ram will be displayed on the top of all layers so no matter what you are currently working and which application is active you’ll always be able to check the necessary information with the zero effort.
    Beeper for S60 Beeper for S60
    Beside the Bar functionality it is also capable to play a sound file of your choice for the every hour or to use one sound as the alert for all 24 hours. If you want the same tone for all hours than it will be enough to select a single sound but if you want to have your own custom Big Ben chimes you’ll have to select a folder that contains 24 sound files named as 00.mp3 …. . . .24.mp3 where the 00-23 are sounds for hours, while the file 24 is for battery.
    Of course notification volume is also adjustable but keep in mind that notifications will not work if your phone is in silent mode. There is an also option to set this hour notification to be activate only from 6 through 23 for example and give you a chance to sleep on the night without interruption by sound notifications.
    That’s not all of course, there is many additional features make this small application much more practical all in one solution. For instance, you can track the battery charging and choose the sound that will warn you once when the battery is full.
    There is also a handy Program starter and you can choose which allows you to choose one application that will be started automatically for certain time. Further more there is an option Restart the phone, Export SMS messages to the txt file and quite surprising call recording feature with customizable pat and format.
    The last but not the least there is an embed simplified version of the his WakeUpMe soft which basically means that it has fully customizable WakeUp assistant that lets you WakeUp with any of your favorite songs, albums or radio stations.
    The best of all, applications is completely free and you’ll get all these useful features free of charge and therefore you should give it a try. If nothing else, once you start using Beeper you'll know exactly what time it is, clock, calendar or any other item can stay always on top and inform you about the time or system status.
    To get it to work you have to install latest Python version. It is also high suggestible to install application and Python in the phone's memory (C: drive). There is no need to sign Beeper but if you sign it Beeper will autostart with phone.
    [​IMG][​IMG][​IMG]
    [​IMG][​IMG]
    ChangeLog :
    - repair function pseudo transparent with resize bar
    - change name "888" to "Set auto"
    - add function "Test starter"
    - add version with icon by AcidSonic
    - source code for all
  8. buimanhthang
    buimanhthang Thành viên
    Kaspersky Mobile Secuirty v7.0.32 S60v3 SymbianOS9.1 Unsigned Cr@cked-illusion
    KASPERSKY MOBILE SECUIRTY.V7.0.32.S60V3.SYMBIANOS9.1.RootSiGNED.SI
    S
    Thanks @illusion
    Sửa lỗi không update được
    Description
    Kaspersky Mobile Security is a convenient and reliable solution that protects smartphones from Internet attacks, malicious programs that target mobile platforms and SMS spam. It also provides protection for confidential data stored on a smartphone should the device be lost or stolen.
    Functions
    Anti-theft protection:
    Protection of personal data for a lost or stolen smartphone. To protect personal data stored on a smartphone if it is lost, a user can block his/her smartphone or delete files, messages, and the list of contacts remotely. The user can also find out who the “new owner” of the lost device is.
    - SMS-Block. In the event of the loss of a smartphone, a user can send a “hidden SMS message” to it, which blocks access to the smartphone until a pre-set password is entered.
    - SMS-Clean. This function is similar to the SMS-Block feature, but, rather than blocking the smartphone, it cleans the device’s memory and memory cards.
    - SIM Watch. The SMS-Block and SMS-Clean functions are only available if a smartphone is enabled and the original SIM card is installed. If a smartphone is stolen, the “new owner” will most likely immediately replace the original SIM card. The SMS Watch function will prevent the “new owner” from accessing any personal data without the initial SIM card inserted in the device. If the initial SIM card is replaced with a new one, the SMS Watch function will send the original user the new telephone number of the device without the “new owner’s” knowledge.
    Antivirus protection:
    All incoming or modified SMS, MMS and email items are automatically scanned for malicious programs.
    On-demand scanning of the mobile device is available at any time. The user can pre-set the best time for antivirus scanning and it will be performed automatically. If an infected object is detected, it is stored in the quarantine folder or deleted.
    Firewall
    The user can select one of the integrated IP firewall protection levels. Depending on the level selected, one or more connections will be restricted to provide user security.
    Anti-spam for SMS/EMS/MMS.
    Telephone numbers of known spam sources, any incorrect numbers (for example, text numbers) or unwanted words or phrases can be added to a blacklist to ensure that such messages are always blocked. You can also add the addresses from your contact list to a white list. In the Symbian version, MMS messages are also filtered.
    Automatic updates.
    Antivirus databases are updated automatically at intervals set by the user. Updates are available via
    WAP/HTTP (GPRS, EDGE, WiFi, etc.) or via a PC during synchronization.
    System Requirements
    Symbian OS 9.1, 9.2 Series 60 (Nokia smartphones only)
    illusion:
    Activated already and it will never get expired.
    The updated database should go here c:\private\200112C4 (hacked phones only)
    http://www.ziddu.com/download.php?uid=a66gmpeua7GelOKnaKqhkZSrZauelpmu8
    http://www.4shared.com/file/5136105..._SECUIRTYV7032S60V3SYMBIANOS91RootSiGNED.html
    quochung803, Leon, lovetodie and 6 others like this.
  9. buimanhthang
    The World FactBook 2008 Encyclopedia packed by Nabilove
    Thông tin về các quốc gia trên thế giới gói gọn trong 1 cuốn sách
    Description
    During last 4 years i promis to my friends to share with them the last World Factbook version in this forum, i come today with a new release in my hand, the version 2008.
    The World Fact Book 2008 is a complete listing of all the world's countries. Includes flags and maps, geographical, demographical, political, economic, military (etc.) data.
    For feedback regarding the content of the fact book itself, visit hxxps://comm.cia.gov/cgi/comment_form.cgi
    What's New?
    - Country information has been updated as of 17 January 2008.
    - In the Geography category, two new fields focus on the increasingly vital resource of water: “Total renewable water resources” and “Freshwater withdrawal.”
    - In the Economy category, three fields have been added that focus on capital stocks and investment. They are "Stock of direct foreign investment - at home," "Stock of direct foreign investment - abroad," and "Market value of publicly traded shares."
    - In the Notes and Definitions, c oncise descriptions have been added of the major religions mentioned in the Factbook .
    - Several notable geographic changes have occurred. The US Board on Geographic Names (BGN) now recognizes Timor-Leste as the short form name for East Timor ; its description may be found under this new designation. France 's overseas possessions have been reorganized. The five former entities of Bassas da India, Europa Island , Glorioso Islands , Juan de Nova Island, and Tromelin Island , previously grouped as Iles Eparses ( Scattered Islands ), now constitute a district of the French Southern and Antarctic Lands . Additionally, the islands of St. Barthelemy and St. Martin, formerly a part of the French overseas region of Guadeloupe , now make up separate overseas collectivities and have their own Factbook entries.
    - Revision of some individual country maps, first introduced in the 2001 edition, is continued in this edition. Several regional maps have also been updated to reflect boundary changes and place name spelling changes.
    Compatible devices
    Symbian S60 All Editions, Symbian UIQ All Editions, Symbian Series 80, Palm OS®, Pocket PC, Windows Mobile™, Windows®, and Windows® CE Handheld PC
    How to install ?
    The world factbook 2008 comes in html format, and than i convert it into .pdb format.
    Why ".pdb" format? because this format is fast than PDF format and Java aplications, it can be used in different devises including Symbian supported devices, it can be read by iSilo software.
    For Symbian S60 3rd edition:
    1- Install iSilo software, you can find the last version vr.5.01
    2- Unrar "CIA_World_Fact_Book_2008-packed-by Nabilove-iSilo.rar" and transfer to your phone memory, put it in "E:/Documents/isilo" directory
    3- Open iSilo software and than chose "CIA_World_Fact_Book_2008" open it and then click on
    Menu(*)-> Edit->Options->Layout->Disable table layout->Ok (*)not the phone menu
    4- For best view u can use iSilo vr.4.36 (tested on E65 and N82)
    5- Enjoy it !!!
    http://www.ziddu.com/download.php?uid=Z6qZl5WrYa%2BinOKnYaqhkZSrXquemJem1
    http://rapidshare.com/files/122684681/Microsoft_Encarta.rar
    Hoang An and kinhcannet like this.
  10. buimanhthang
    HNHSoft Talking English-Chinese Dictionary Cách BinPDA
    Learn Chinese today and speak with confidence! HNHSoft English-Chinese Dictionary is a great dictionary for Chinese language students. It contains over 60,000+ entries, Pinyin (the official Chinese phonetic system), and most remarkably, a real person's pronunciation for every single Chinese word! The dictionary also provides a great study tool that allows you to organize your own list of words. You can review the words any time you want, as often as you want, and even test if you have memorized your words. No matter you are already bilingual, a beginner, or just a traveler that needs a translation tool, you will find this dictionary extremely useful!
    [​IMG][​IMG][​IMG][​IMG]
    Key Features
    30,000+ English to Chinese entries in English-Chinese Dictionary
    30,000+ Chinese to English entries in Chinese-English Dictionary
    Real person's pronunciation for each Chinese word
    Pinyin (Chinese phonetic system) for each Chinese word
    Support both Simplified and Traditional Chinese
    Built-in Chinese Input Method
    Great study tool
    Recently viewed words
    No Chinese platform requirement
    Supported J2ME Phone Platforms
    Samsung SGH-i560,Sony Ericsson M600,Sony Ericsson W950,Nokia 3230,Nokia 6670,Nokia N93i (S60 3rd Edition),Nokia 5700 (S60 3rd Edition),Nokia 6290 (S60 3rd Edition),Motorola MOTO Z10,Nokia N76 (S60 3rd Edition),Samsung SGH-D730,Sony Ericsson W960,Nokia 6110 Navigator,Sony Ericsson P1,Motorola MOTO Z8,Nokia E90 Communicator,Nokia 6120 (S60 3rd Edition),Nokia N75 (S60 3rd Edition),Nokia N77 (S60 3rd Edition),Nokia N80 IE (S60 3rd Edition),Nokia N91 8Gb (S60 3rd Ed.),Nokia 7610,Nokia 6620,Nokia 3250 (S60 3rd Edition),Nokia 6680,Nokia 6681,LG JoY,Nokia N95 (S60 3rd Edition),Samsung SGH-i520,Nokia N80 (S60 3rd Edition),Nokia N71 (S60 3rd Edition),Nokia N72,Nokia N73 (S60 3rd Edition),Nokia N70,Nokia N92 (S60 3rd Edition),Nokia E60 (S60 3rd Edition),Nokia 6630,Nokia E61(S60 3rd Edition),Nokia E50 (S60 3rd Edition),Nokia 5500d (S60 3rd Edition),Nokia E70 (S60 3rd Edition),Nokia N90,Nokia N91 (S60 3rd Edition),Nokia 6260,Nokia N81,Nokia E51,Nokia N93 (S60 3rd Edition),Nokia E62 (S60 3rd Edition),Sony Ericsson P990,Nokia E65,Nokia E61i,Sony Ericsson M600i,Nokia 6682,Samsung SGH-D720,Nokia N82,Nokia 6121,Sony Ericsson P990i,Samsung SGH-i400,Samsung SGH-i450,Samsung SGH-i550,
    link
    http://ucash.in/2a9710d
    http://u-elg00dhnz.urlcash.net
